Author Topic: Light Weight Wind Turbine Project - as I build it.  (Read 248347 times)
sean_ork
Re: Light Weight Wind Turbine Project - as I build it.
« Reply #561 on: May 30, 2012, 01:24:50 PM »
using bulbs in any dump load system is a very very bad idea - bulbs have a finite life
better to use a properly rated and proven dump using resistance wire etc ......
sean_ork
« Reply #562 on: May 30, 2012, 01:28:57 PM »
also, that charge controller is aimed at PV - PV controllers tends to simply disconnect the supply when float voltage is reached
a proper wind mill charge controller should divert the mill output to a dump when float voltage is reached
I have a number of these very fine controllers here for the smaller mills
http://www.ebay.co.uk/itm/PWM-Charge-Controller-and-diode-Wind-Turbine-Generator-/320900539474?pt=UK_Gadgets&hash=item4ab729a452#ht_1692wt_1102
fabricator
  • My smoke got out again
« Reply #563 on: May 30, 2012, 01:45:41 PM »
The dump load controller is connected to the batteries only, it is not in the circuit from the turbine to the batteries at all, if you want a good cheap controller look up the Gurd controller here or on the another power site.
Coleman air also makes some very reliable charge controllers I used the kit for a long time, it's around 60 bucks all you have to do is mount it in a box and hook it up, it's adjustable for dump range and has three LEDs for battery state of charge and whether it's dumping and stuff. http://www.colemanair.us/vp_asp/scripts/shopdisplayproducts.asp?id=1&cat=Controllers%2FRegulators.
If that thing makes 13 volts at 80 rpms you can slap me in the ass and call me Sally.
Steadfast
« Reply #564 on: May 30, 2012, 01:49:10 PM »
Hmmmm,
£52 is equivalent to 81.1 United States dollars...
and postage to NC. USA is how much?
Steadfast
« Reply #565 on: May 30, 2012, 01:50:28 PM »
Ha ha ha ha!
and the competition is OOOON!
GOD...I just LOVE Free Market Capitalism!
This one is also Looking GOOD! and it is only $60...
what is that button on it for?
« Last Edit: May 30, 2012, 01:58:54 PM by Steadfast »
sean_ork
« Reply #566 on: May 30, 2012, 01:54:21 PM »
I'm sure you could find that out all by yourself, took me 5 seconds
fabricator
« Reply #567 on: May 30, 2012, 02:06:02 PM »
What one are you talking about?
Steadfast
« Reply #568 on: May 30, 2012, 03:25:57 PM »
Your Coleman air suggestion...
where can I find a DC light bulb?
fabricator
« Reply #569 on: May 30, 2012, 03:33:18 PM »
The red button is to manually dump or test the set point you have it at, all mobile equipment has DC light bulbs but you DO NOT WANT TO USE A LIGHT BULB AS A DUMP LOAD!!!!!
Go over to lowes and buy a cheap electric heater of some kind.
« Reply #570 on: May 30, 2012, 03:35:51 PM »
Steadfast;
Send GHURD a PM , he's one here as a GM too, BUT even better his dump load controller IS known WORLD wide and works!!
This can be verified by several people, he can also supply the resistors (if he has any left), I'm thinking can be done far less than some would charge in postage.
BTW: I have no less than 3 online at any one time.
you can look at his website by clicking on www.GHURD.info too :_)
He works nights so it may be a day or two before he responds, BUT I'll stand by his product!!
sean_ork
« Reply #571 on: May 30, 2012, 03:46:24 PM »
I must say you chaps have the patience of saints
Steadfast
« Reply #572 on: May 30, 2012, 03:52:47 PM »
I was thinking about buying Fabricator's "coleman air controller" and 2 or 3 of these.
2 OHM 100 WATT POWER RESISTOR DIVERSION DUMMY LOAD 12V
$10 each...
I was thinking I could rig up 2-3 of these rods in series and add a 100watt DC light into the series as well. that way I still get my grovey out door light...
BTW what tempiture will one of these 100 watt thingys get up too?
I dont want to burn down my shed...  How hot is 100watts?
« Last Edit: May 30, 2012, 04:00:29 PM by Steadfast »
« Reply #573 on: May 30, 2012, 03:55:04 PM »
We like helping people who are willing to learn and put up with being run through the wringer a time or two. AND in Steadfasts case 4 or 5 times.
Had he not shown the wherewithal we would've not gone this far a long time ago.
Cheers;
Steadfast
« Reply #574 on: May 30, 2012, 03:55:52 PM »
Thanks Bruce!  ;D
Hey, this is not about only me...
This is about the other poor slobs, like me, who want to build a Turbine...  :o
« Reply #575 on: May 30, 2012, 04:00:16 PM »
I was thinking about buying Fabricatore's coleman air controller and 2 or 3 of these.
I was thinking I could rig up 2-3 of these rods in series and add a 100volt DC light into the series as well. that way I still get my grovey out door light...
Here's the thing.
The dump controller MUST be able to handle (dump) as much of the output the windturbine is going to be able to output (Meaning PEAK output).
Thus it needs to be sized this way.
So let's say ChrisO's runs and is able to say output 13.5Vdc at 300watts max. You'll need to then build the dump load to handle the max amount without burning up or going open ans that would of course cause an unloaded turbine which is worse IMO than boiling a battery or two.
Steadfast
« Reply #576 on: May 30, 2012, 04:01:49 PM »
« Last Edit: May 30, 2012, 04:27:18 PM by Steadfast »
fabricator
« Reply #577 on: May 30, 2012, 04:07:33 PM »
" The patience of saints" ROTFLMAO! Not as a general rule. ;D
« Reply #578 on: May 30, 2012, 04:07:46 PM »
Thanks Bruce!  ;D
No worries.
PS> I sent Ghurd an email asking him to pop in here and do the numbers and let you know about HIM sizing one correctly. He normally does then numbers faster in his head while driving to work!!
WE know its more than just about you, we also know its more than just picking on the RED Alternator :_), there are some who are hoping he comes through and it works.
WE hate seeing US based companies go belly up unless they aren't willing to go the extra mile to get things understood.
« Reply #579 on: May 30, 2012, 04:09:42 PM »
True BUT he took all the cramp we could throw at him and he's still willing to learn and come back for more  ;D
« Reply #580 on: May 30, 2012, 04:10:46 PM »
Think toaster hot when in full dump mode!!
fabricator
« Reply #581 on: May 30, 2012, 04:11:58 PM »
Did I mention you talk like David Niven? ;) (Watched the "Guns of Navarone" last night)
« Reply #582 on: May 30, 2012, 04:14:08 PM »
Light bulb is a bad idea. If it burns out your system could become unloaded.  You need around .4 ohm of load at 350 watts. 5 in parallel will get you to .4 ohms so that may be what you want but I don't know the exact specs of the wind turbine so it may be to small.
fabricator
« Reply #583 on: May 30, 2012, 04:16:09 PM »
That you gotta give the guy, since this thread started two or three other newbies have stomped off in a huff, and I believe one was banned. LMAO.
fabricator
« Reply #584 on: May 30, 2012, 04:19:04 PM »
If you want an outdoor light, plug it into the inverter like everything else.
sean_ork
« Reply #585 on: May 30, 2012, 04:22:13 PM »
I find it very frustrating reading questions, such as DC light bulbs and bulbs for dump load - I do wonder if Steadfast ever reads anything other than the content of this thread - we call it spoon feeding here
no offence intended Steadfast, just an observation from someone with a little less patience  ;)
Steadfast
« Reply #586 on: May 30, 2012, 04:27:31 PM »
I am looking at buying these:
Q-JD10140S Plusrite 3451 - 100 Watt - T4 - DC Bayonet Base - Halogen - Clear - 2,000 Life Hours - 1,200 Lumens - 120 Volt   $1.53 each X10
  SATCO-901560 DC Bayonet Socket with Mounting Bracket - 500 Watt - 125 Volt - 9 in. Leads - Satco 90-1560 $3.42 each - Just one
and combining it with 3 (or 5)of these:
wired in series and all mounted somehow on a concrete brick plate on the outside of my shed...
If I rig up 5 of these their tempiture will be spread out, right???
EI: hotter with only 3, cooler for 5???
sean_ork
« Reply #587 on: May 30, 2012, 04:30:53 PM »
having a bulb across a dump is a good way of knowing at a glance when the battery if full - having a bulb in series is a very bad idea
Steadfast
« Reply #588 on: May 30, 2012, 04:32:54 PM »
Yes, that is why I want to do it...
I can always wire the light in a seperate parrellel...  right?
sean_ork
« Reply #589 on: May 30, 2012, 04:36:15 PM »
do you know the difference between parallel and series wired ? - your previous post about putting a 100w DC light into the series is rather open to misinterpretation
sean_ork
« Reply #590 on: May 30, 2012, 04:38:30 PM »
you might also wish to confirm which mill you are proposing these parts are for
the toy one or the adults one - both will require a different setup
« Reply #591 on: May 30, 2012, 04:38:50 PM »
FAB;
ME TOO!!! First time I've ever been accused of being a SAINT!!
« Reply #592 on: May 30, 2012, 04:41:55 PM »
NOT really, if the one is setup for ChrisO's unit , then from my calcs, it'll certainly handle the RED Delco.
The other one I would not call a toy. A toy one would be one you would buy from Edmond Scientific to teach kiddes and isn't much more than something that would sit on a table.
Even if it doesn't work as planned, it's still not something I would consider a toy.
JMO.
Steadfast
« Reply #593 on: May 30, 2012, 04:43:05 PM »
If I rig up the dump for the Big one, it will be redundant over kill for the smaller one...
