Author Topic: USB charging with solar panel  (Read 4198 times)
Larsmartinxt
  • Country: no
« on: April 15, 2012, 11:05:26 AM »
This is my first contribution to this forum
I got tired of those cheap solar USB chargers that never works so I decides to make my own.
The panel I made is a bit of overkill for the rest of the circuit as the charging done is only 5w from my boost converter. But this makes it work in partly cloudy weather as well as in bright sunshine.
Panel consists of glass/eva/solarcells/eva. Didn't use tedlar as I couldn't find it :P
The Boost converter boosts voltage from 0.7V up to 5V so it could work with as few as 2 cells. Had the circuit board made professionally as I ordered 50 :)
Anyway let me know what you think.
Re: USB charging with solar panel
« Reply #1 on: April 15, 2012, 12:54:09 PM »
Nice work: is the boost circuit your own?
Larsmartinxt
  • Country: no
« Reply #2 on: April 15, 2012, 01:47:11 PM »
Yes I made the boost circuit. It's core are the MAX1674 chip
Charges my cellphone in a couple of hours
« Reply #3 on: April 15, 2012, 06:04:02 PM »
That is 'backwards" from anything I ever saw.
Stepping down to USB from 12~24V nominal is more common.
Nice work!
Larsmartinxt
  • Country: no
« Reply #4 on: April 15, 2012, 07:57:51 PM »
Nice work!
Yeah well I figured when I only need a few watts why use a bigger panel...  This is for charging cell phones,GPS and such when going tenting :P
« Reply #5 on: April 15, 2012, 08:06:12 PM »
"I figured when I only need a few watts why use a bigger panel"
Watts is Watts is Watts, but I know what you mean.
« Reply #6 on: April 16, 2012, 03:24:45 AM »
Can you link to or attach a schematic?  Is it a huge secret?  B^>
Larsmartinxt
  • Country: no
« Reply #7 on: April 16, 2012, 11:53:13 AM »
I could post it but then I'd have to kill you.. :)
« Reply #8 on: April 16, 2012, 01:38:17 PM »
Thanks: nice and simple!
« Reply #9 on: May 02, 2012, 12:51:55 PM »
Nice project.  I made an imperfect panel of about 3 volts or so a while back, laminating it in a vacuum oven.  It does about 2.5 Amps and apparently might make a nice cell phone charger.  OZtules has used Tedlar, commonly sold in building supply places as a backing on some panels, I believe with success.  He has a nice writeup about how he builds his panels on here too.  Rich
Larsmartinxt
  • Country: no
« Reply #10 on: May 03, 2012, 03:49:05 AM »
I actually used a professional machine for laminating solar panels. This was on the lab of a local solar cell manufacturer.
Was planning to use Tedlar. but someone had misplaced the roll so didn't use it this time.
Yes you could use that panel no problem.
I've been reading that writeup and it's excellent. Was planning to use that method. And will probably use it later.
« Last Edit: May 03, 2012, 03:59:05 AM by Larsmartinxt »
