Author Topic: TECs, Peltier  (Read 3827 times)
slapstick
  • Thinking outside the TV
TECs, Peltier
« on: May 27, 2012, 06:36:14 PM »
Has anyone ever used a TECs to make power, If so please share... I need all the help I can get on this subject:)
Trying to think in the 6th dimension.
Re: TECs, Peltier
« Reply #1 on: May 30, 2012, 12:09:47 PM »
Google is your friend  8)
Use the search tab on here, you should find a post that could be of a massive amount of info/help.
Remember these products are built for a different use and so are VERY low in what you are attempting.
IT is doable, just not as efficient as you may think
Best of Luck!!
Frank S
Re: TECs, Peltier
« Reply #2 on: May 30, 2012, 04:47:36 PM »
just remember search engines are only as good as the key words entered The search here does not do well abbreviations
XeonPony
  • Sanity is over rated!
« Last Edit: May 31, 2012, 12:44:56 PM by XeonPony »
Frank S
Re: TECs, Peltier
« Reply #4 on: May 31, 2012, 02:59:20 PM »
I can see them being used to recover some energy from wasted heat providing there was a source of cold next to the heat source .but  since  I am not up on the factors of recoverable power versus the cost of the set up and @ what rate of recovery could be expected for a return on investment.
 Maybe a solar array over a cold flowing stream or small river.
mab
Re: TECs, Peltier
« Reply #5 on: May 31, 2012, 05:22:34 PM »
for info on using them the 'other way around'  it might be best to google 'seebeck effect'.
In my limited experience, it's difficult to get useful power out of them - unless you just want a very small amount of power - I've heard that they are used on oil pipelines to power sensors (using the temp difference between pipe & ambient), but I don't have any more info.
slapstick
Re: TECs, Peltier
« Reply #6 on: June 06, 2012, 06:43:54 AM »
Thank everyone for the help!
 I will do my homework and make something happen.
Its just that everything I have seen in Google search that has been build ...... well if you ask me it was all half ass done.
But maybe that's all its worth doing. I know that the hardest thing to make is the temperature differential on the hot side. My heater runs at 150C so there is the heat, now for the cold side. I was thinking of a tank in the ground pumping around the heat sink if it was needed to make the delta T.   With my heater running at 100 watts @ 300F and the outside air @ around 30F in the winter to 80 in the summer. That's a Delta T range between 270F and 220. Using this setup the TEC/TEC  should be around at lest 10% to 20% efficient. I will be setting up 4x 400 watt TECs... Well I guess we will just have to see what I come up with.
Re: TECs, Peltier
« Reply #7 on: June 06, 2012, 09:08:57 AM »
That would be a very nice Delta/t.
There was a gent on here a few eyars back that did a very good job of even taking it so far as to using an old 1Meter dish to raise the heat side, since the "upgrade" I have not been able to find much of the older stuff.
Best of Luck, keep us tuned in:)
slapstick
Re: TECs, Peltier
« Reply #8 on: June 07, 2012, 05:27:07 AM »
Will do ;)
Like always thank you all for the help and feed back.
Re: TECs, Peltier
« Reply #9 on: June 29, 2012, 11:10:24 PM »
Be advised that they have a life expectancy based on the number of cycles.
Powering a mini-fan on a wood/coal stove somewhere cold may only be a couple cycles a month (north slope?).
Other situations may be a few dozen cycles a day (my car's catalitic converter).
Junkie
    • Scraptopower.co.uk
Re: TECs, Peltier
« Reply #10 on: September 06, 2012, 12:49:28 PM »
I have built a few little thermoelectric generators. There's some info on my website about them My latest one is shown below!
Quote from my website :
"This strange looking pan is a device to generate power from a low temperature heat source. By using the seebeck effect, it is able to produce enough electricity to charge a cell phone and other USB devices. The best part about this contraption is that it has no moving parts.
The device has a nimh power pack which stores electrical energy for use whenever you need it, the power pack can be detached for use anywhere. The output is 5V through a USB port. This device would work especially well were there is snow available for extra cooling – for example off grid cabins in remote (snowy!) locations. The bigger the temperature difference between the two sides of the peltier the bigger the power output. "
From www.scraptopower.co.uk
