Thurmond
I looked on the outback teck forum and I believe the mx 60 is self limiting of amps based on heat. I wish you would look your self and not just take my word for it. It was mentioned that 100 amps wouldn't hurt it but you are only getting up to 70 amps max based on heat. There is a setting to increase the amps to 70 but that doesn't mean you will get it if it runs hot. Some put heat sinks, take covers off and place fans on them to increase output. I think you can use it but it might slightly reduce the chargers output. I could post a link if you want to read it yourself. I wouldn't go over voltage though. I hope i am not screwing this up, but I think I am not.
good luck
gww
