Author Topic: 500 watt PV system  (Read 1689 times)
Jon Miller
    • Otherpower UK
500 watt PV system
« on: October 27, 2012, 07:51:42 PM »
Hello all,  This is a UK show and tell.
Just thought I would upload a couple of pictures of my small grid tied PV system.
This system consists of two Suntech 250 watt mono panels and a single Enecsys Duo 480 inverter.
Fitting has been done using bolts for the K2 frame and a Solar Flash for the cable entry.
The system is south east facing and suffers from some shadding on the bottom panel for most of the day from cables in front of the house.  About three months each side of the longest day, the shaddow should not have an affect.
DC is bought off the roof through the loft to the back of the house in the downstairs kitchen, inverter is located in a cold corner for a bit of free heat.
I belive the system will do about 300kWh a year.  I am on the £0.21 fit rate in the UK.
I am happy with this system and using my Current Cost meter I can keep a good idea on what is being used.
Jon
Jon Miller
    • Otherpower UK
Re: 500 watt PV system
« Reply #1 on: October 28, 2012, 07:59:39 AM »
Bit more data from the inverter as of today.
Intresting post on another baord about the Zigbee communications Enecsys works with.
http://www.navitron.org.uk/forum/index.php/topic,18276.0.html
