Product Reviews > Reviews
BZ 500MPPT assembly issues
boB:
I had heard that the BZ does not actually go to Float ? Is this true ?
If it were to just stay in Absorb all day long at the highest regulated voltage, this would not be good.
Were the rumors true or false ? If it actually has a Float LED, I would think it would intend to go to
Float after some amount of time in Absorb.
boB
dnix71:
I don't know if my BZ is three stage, but it most definitely has a float. It also has a two-stage charging circuit. Near the float voltage it backs off charging. The float light will flicker, but if there is lots of sun, it will go hard red and sit there until either the batteries voltage drops from a load or the sun goes down.
The final voltage is adjustable so it shouldn't matter what kind of battery you have. You can set it to cut off in the low 13's, or florce it as high as about 15.5.
Navigation
[0] Message Index
[*] Previous page
Go to full version
