Patent pending...I don't want to disclose too much. My aim here is to figure out if I'm missing anything.
The rotor's Diameter is 74"
The Speed measuring device is a Specialize cycling computer.
The wind speed meter is just a hand held anemometer located just below midway in front of the rotor
The scales or two digital rapala 50lb fish scales...( I do not recommend these for testing, they kept turning off)
I've attached a redacted photo of one of the test pictures. To record RPM, I used the cyclometer,(the red object), to arrive at rpm multiply the speed reading by 9. The wind speed meter is the black object next to the two Rapala fish scales. The pulley is 6" diameter made of plywood. The Belt is made of 3 layers of nylon webbing with copius amounts of a substance called "Belt Grip". My first attempt was a wrap of polypropylene rope which burned through in about 20 minutes. I felt like Roy Schneider in Jaws, '...think I'm going to need a bigger brake.' I had a rope tied to a lever tied to the "high side" fish scale the low side fish scale was tied to a member on the support. My camera and myself were located about 30 feet upwind.
Why it's volumetric, All the typical hawts measure their power based on planar geometry even though in reality they are not acutually planar. They compress their 3dness into a very short space resulting in a twist in the blade, (which by the way makes it more difficult to manufacture). This blade does not sport a twist. I expanded the geometry outward.
Also the typical blades are high aspect ratio type blades, sort of like an albatross, this rotor's blade is more like an eagle or an owl capable of pulling heavy objects from the water. Very low aspect ratio.
The Spreadsheet is from an afternoon of testing
