Hold on to your hats boys this is going to be a wild ride.
I found a graoh in a Scientific American article showing panel output in % of panel rating vs. time of day. [ Specified attachment is not available ] [ Specified attachment is not available ]
This is for a 12 hr. day where the sun strikes the panel at 0 deg. at sunrise, perpendicular at solar noon and again 0 deg. at sunset. Because the sun will strike your panels at an angle greater than 0 deg. during any other length of day.
I have used this graph to show the panel output for your location with 10:30 sunrise and 2:30 sunset. The black area represents the power your panels will gather during this period.
This picture represents the power your panel would gather on top of the mountain, assuming 8 hours of sun. (I have no idea how many hours you actually get as you haven't provided this or your location)
Again the shaded area represents power gathered, in this case 8am to 4pm.
The maximum power gathered in all cases is about 70% of the panel rating, this take into consideration many variables
but is close to real world values.
Picture 1 shows an average of 68% of panel rating for 4 hrs. this times your panel rating of 3600 watts
gives you 9792 whrs of production in the valley.
Picture 2 shows an average of about 55% of panel rating for 8 hrs. giving you 44%hrs. this times 3600 watts
gives you 15840 whrs. of production on the mountain top.
Now taking into consideration voltage drop in the 2 cases using 100 ft of 2ga. aluminum in the valley and 1300ft on the mountain top and because voltage drop is linear with both amperage and conductor length I used an average of 68% of 32 amps for the valley and an average of 55% of 32 amps on the mountain top
the calculator shows a .89% drop for the valley so 99.11% of 9792 watt hrs would give you 9705 watthrs.
The calculator shows a 9.4% drop on the mountain top so 90.6 % of 15840 whrs would give you 14350 watthrs.
This shows about 50% increase in output by moving the panels to the mountain top.
Moving the panels would cost $1000 more for wire.
Adding 1800 watts of panels in the valley to get the equivalent output would cost 1800w X $.85/w =$1530 plus an extra or larger charge controller.
There are hundreds of variables which would change these numbers but this gives you a rough idea of what you can expect.
