dear all,
I am in progress of building the Piggotts 3 meter turbine.
First some info
rotor diameter 3,4 meter
2 Stator disks 300mm x 10 mm thick
12 magnets per rotor NEO N40 46 x 30 X 10 mm
9 Coils 1,7mm (about awg14), 57 turns 2 in hand, star connection.
estimated TSR of blades =7
3 blades
Coil thickness 17mm
Coil leg with 30 mm
I would like a cut in speed of about 165 rpm. If i put a testcoil on the lathe and turn 165 RPM on the stators, how much should one coil read?
24 volts +1,4 (rectifier) / 6 coils = 4,2 volts open circuit? correct?
Some more doubts:
1)Coil leg with is 30 mm like should be as per Piggotts recipe book. seems a lot to me. when one magnet is just on top of one coilleg another magnets starts to be above the first leg... somewhere i read voltages wil cancel each other out... (see pic)
2)Coil thickness is 17 mm + 1 mm for fiberglass cloth + 2 x 1,5 mm airgap =21 mm. compared to magnet thicknes of 2 times 10mm. slichtly above max. i read a lot of theories that space between magnets schould be 1,5 or sometimes 2 times the magnet thickness... what is correct?
3) coil legs schould be parallell (shoulder to shoulder). although I made coil litlle tapered (30 mm top width and 25 mm bottom width) the coils wil not lay parallel... could that be a problem?
Thx in advance for replies/advice. will keep u posted about progress but waiting for my stainless steel studs for the bearings.
