Author Topic: Motor run capacitor?  (Read 1625 times)
wml52
« on: May 21, 2014, 11:58:00 PM »
Hello to all,
I have an old (1997) Generac 1140-2 5000 watt, 6250 surge watt generator with a failed capacitor. The OEM p/n A1817AGS is a 440 volt 35µF +/- 5% cap and from what I was told is no longer available. I did locate a few on line but the prices ranged between $80.00 and  $125.00.  I did find motor run capacitors with the same values starting around $10.00. Can I use a motor run capacitor rather then the OEM and if not what would the difference be?
Considering the age of the generator I can't see spending the $$$ for the OEM part.
Any thoughts would be appreciated.
Bill
Re: Motor run capacitor?
« Reply #1 on: May 22, 2014, 05:17:30 AM »
Yes a motor run capacitor should be fine. Go for 440v rating and parallel to get capacity if you can't find a single 35uF
