Author Topic: protection diode, better alternatives  (Read 1394 times)
kitestrings
« on: August 20, 2015, 01:40:09 PM »
Regarding our axial-flux controllers & protection scheme...
One detail I wanted to ask folks here.  Dgd had cautioned us earlier about the "protection diode" that we are using - should it fail.  Briefly, we have Aux2 output of one controller connected to our 3-ph load bank (home-made clipper) via SS relay.  This signal is 12V.  We also have an Omron voltage sensitive relay connected to this relay, but it is a 24V output.  The diode, Dgd pointed out is the only thing separating the two, different outputs.  I just wondered if any one might suggest a better protection scheme?  I've seen some small, low-power switch-mode DC/DC converters...there are DIN rail power supplies (a bit pricier)...or maybe just a linear voltage regulator?  I'd like to keep it simple.
thanks for any suggestions, ~ks
