Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
Shut off switch
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Shut off switch (Read 1472 times)
go4it
Newbie
Shut off switch
on:
January 08, 2016, 01:41:06 PM »
i want to change the way I shutdown my 12v windmill. I wonder if I can get away with leaving the ground connected and adding a two way switch that connects the windmill positive to either the battery positive or the common ground?
Logged
mab
Sr. Member
Country:
Re: Shut off switch
Reply #1 on:
January 08, 2016, 07:34:47 PM »
So the mill is either connected to the battery or shorted? I guess that would work - but make sure it's a proper break-before-make switch, and make absolutely sure you can't confuse the connections to the switch 'cos you don't want to short the battery to gnd instead
Logged
klsmurf
Full Member
Country:
"Damn it Jim, I'm a carpenter, not an electrican"
Re: Shut off switch
Reply #2 on:
January 08, 2016, 08:56:35 PM »
I guess you're talking about a DC mill? I was told that shorting a DC mill like that was not good. High speeds may burn the mill up. I believe it was Ghurd that
suggested to load the mill with some lights to slow it down first.
Logged
go4it
Newbie
Re: Shut off switch
Reply #3 on:
January 08, 2016, 09:32:09 PM »
I try not to stop it if it is spinning quite fast by I have had to stop it in a high wind and it stopped without incident.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
Shut off switch
