Hi all!
I will try to repair and improve a windturbine from a local, creative bar in Antwerp, Belgium:
The windturbine:
One of the PVC-blades is broken, probably from freewheeling. The alternator seems to be intact: each phase measures 1,5 ohm and the bearings/tolerances are ok. The original creator also had an enclosure built around it:
I tried to match it to the Hugh Piggot design, but it seems to be a bit smaller:
Neo: magnets are 66% smaller, but the rotor has an extra stack
Rotor: 20cm, whereas Piggot's rotor is 23 cm (1,2m single rotor windturbine) or 26cm (1,8m dual rotor windturbine)
Wire diameter: unknown
Due to the ineffeciency of the PVC-blades, the stator probably never burned out. (It has no furling or electronic short-circuit/-brake whatsoever). I'll upload a picture of the old PVC-blades but the root had a curve of 90° which was acting as brake. I don't have a crazy amount of time so I will make PVC-blades again instead of wooden ones. I will use the PVC-blade-calculator from Wind&Wet:
http://www.windandwet.com/windturbine/tube_blade/index.phpThe bar is located in the outskirt of the city, at the harbour, so it has some good wind coming in. Since the tower is only ~5m high, I estimate the average windspeed at 3,5-4m/s. The map states 4,1m/s:
I'm looking for some recommendations for the length of the new blades. Originally they had a length of 58cm. But Hugh Piggot uses the same volume of magnets for his 1,8m turbine, but the diameter of my alternator is smaller (see above).
Also I am wondering how bad an alternator encasing is. Since the rotor disks are rusty it will be hard to give it a decent paintjob to make it weather resistant (we have 800mm/year rain here
) Other ideas and general recommendations also more than welcome!
The most important thing for this project is showcasing that windturbines can be made by everyone. Electricityproduction is welcome but not top priority.
