GreenTeam,
Here are the details that you need to build the bicycle generator as shown in the picture in the above post.
The following calculations are for using a bicycle with a 26-inch tire and a 6 1/2 inch rubber tire on the generator. If you use different sizes for the bike or the small tire, the number of turns in the coils need to be changed accordingly.
The calculations assume pedaling the bicycle at 45 RPM. With the average gear ratio of 2.33, the bicycle tire will rotate at 105 RPM. If the small tire on the alternator is 6 1/2 inches in diameter, the alternator will rotate at 450 RPM.
At 450 RPM, the alternator voltage will be about 14 volts DC. If you pedal faster than 45 RPM, the voltage and amperage will increase and the 12 volt battery will start charging. If you pedal fast, you can pump 5 amps or more, at close to 15 volts DC into the battery.
The coils need 90 turns of .91mm (19 Ga.) wire. To get .91mm you need to wind 3 strands of .5 mm (24 Ga.) wire in hand.
The alternator has 2 steel rotors but only one rotor has magnets. One rotor has 6 magnets and the other steel rotor has no magnets. For the metal rotors, you can use the standard 7 1/4 inch circular saw blades. I am sure you can find used blades. I would use 2 blades per rotor to increase the thickness to prevent saturation and get higher flux.
For the magnets, you need to stack 3 of those 25 x 15 x 3mm together, then glue another set of 3 next to it, as in the diagram. Each magnet will be composed of 6 little magnets. You will need 36 magnets total.
The best way to glue the magnets together is using epoxy. Make sure that you clean the magnets with isopropyl alcohol before gluing them.
For anybody else who wants to build this, the best magnet size to use is 1 x 1 x 1/2 inches.
For those that don't have a 3D printer, it would be even simpler to cast the stator in resin. The stator form can also be made from a 1/4 inch sheet of polyethylene.
This is a 3-phase alternator. Normally, for 9 coils you use 12 magnets. By using 6 magnets, you keep the cost low and still get about 80 watts. That is the average sustained power that a normal human can produce using a bike.
This little generator can be used during a power failure to charge phones, for LED lights and if you use the full 12 volts from the battery, you can run a laptop.
This is a USB module that can be used with this. They cost about $6 US.
A few years ago, my power went out for 18 hours. I had a bike generator similar to this one. Using a bike and a cheap 12 volts 400-watt inverter, I was able to keep the food in my refrigerator and a small chest freezer from spoiling. My wife and I took turns pedaling. It was cold outside, so the pedaling helped to keep us warm.
We also heated cans of soup using a small microwave oven that we keep for emergencies.
Anybody that wants to build something like this and has questions, just ask.
Ed
