Author Topic: SPD 2P DC Lightning Surge Protector Protective Low-voltage Arrester Device Solar  (Read 1821 times)
fabieville
I want to purchase a SPD 2P DC Lightning Surge Protector Protective Low-voltage Arrester Device for my solar system but i am unsure as to which one to pick.
I have (2) solar system. One system is using a mppt charge controller that can handle a max input of 500vdc running a 48v system and i am currently sending little bit over 200volts dc to its input from the panels and the other system is using a mppt that can handle max input of 150volt dc to it running a 24v system and i am currently sending around 70volts to it and in the future i might increase the input going to it to about 100 plus if i upgrade it to 48v.
If i am to buy a SPD 2P DC Lightning Surge Protector Protective Low-voltage Arrester Device for each solar system which size should i buy for each. They have them in DC 500/800/1000 Volts as u can see in the link below:
https://www.aliexpress.com/item/4000144841221.html?spm=a2g0o.detail.1000060.1.4cfb6e5frnXx9X&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=44294d85-6120-4174-a0c9-b98e2732f863&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:44294d85-6120-4174-a0c9-b98e2732f863,tpp_buckets:668%232846%238113%231998&&pdp_ext_f=%7B%22sceneId%22:%223339%22,%22sku_id%22:%2210000000440037615%22%7D
I am thinking a 500VDC one would be ok for each of the system that i mention above?
I do not know, but I think that you'd need something that clamps to well under the maximum input voltage of each system.  It may not even be possible given how nasty surges can be.  But from what you've said I don't think a 500V device is even enough for your 1st system, certainly not the 2nd.  But maybe I'll re-read when at my desk...
Go with the 500 volt.
Devices SHOULD be designed with some surge suppression built in and the lightning arrestors take that into account. They have to be rated high enough to not trip all the time from normal device operation.
My ham radios have a surge diode in them, it is rated at X voltage and has to be high enough that close in signals don't trip it and cause signal distortion, and it doesn't trip on transmit and distort the outgoing signal. Then I add on lightning snubber devices to protect against very high voltages and I have to rate them high enough to withstand the voltages present on my high power amplifiers outputs. So most won't kick in until 1,000 volts is reached!
In a solar system your DC lines can and will pick up incidental AC pulses from nearby radio transmitters, power lines etc. You have more on that cable than just the DC from the panels. That is why the higher voltage ratings, you don't want them tripping and dropping your solar output. A thunderstorm 5 miles away can induce 400+ volts on a buried cable for example. Not close enough for a near strike but you are still seeing effects from it as the ground potential rises and falls with the electrical energy in the storm.
fabieville
Below is a link on ebay with a PV Combiner Box with one of the SPD install and it is a 1000vdc one. Can i install one in my combiner box just like how it is install in the photo? and using the 1000vdc for both systems would be ok?
https://www.ebay.com/itm/203477975158?hash=item2f603b8076:g:FuwAAOSw0QdhPX0z
14349-0
If they are a din rail mount like the ebay link. I would stick to 500 volts though... unless you plan on taking your solar over that...
