Author Topic: Lift Anxiety  (Read 689 times)
Lift Anxiety
« on: November 08, 2021, 10:37:37 PM »
New tower is ready to go up...
14450-0
Yesterday was too windy to do the first lift.
Now the clocks are set back to standard time, so after work it's dark already.
I probably won't get to do this until next weekend.
In the meantime, I wait...
...but I keep asking myself, "have I forgotten anything??"
clockmanFRA
  • Country: fr
    • Renewable Energy creation
Re: Lift Anxiety
« Reply #1 on: November 09, 2021, 03:07:49 AM »
Check, check and double check!.
 I always get worried about the gin pole and its 3 wire or rope stays, never to tight, but never to slack.
I worry over the gin pole bolt, and always replace with new bolt if suspect.
I worry about the Gin pole plate the gin pole is attached to on the mast and on the gin pole.
Keep checking that your electric wires are not trapped or being squeezed or kinked by the tower going up. Only had that once,.... but!
And i have my lowering/raising  my gals reasonable sweet operation.
Oh yea, one more thing, underwear ! LOL.
Good Luck
Bon Courage!
kitestrings
Re: Lift Anxiety
« Reply #2 on: November 09, 2021, 08:39:05 AM »
Good luck.  Remember, you've done this before.  In the end the planning pays off.  Be patient.  Be safe.
Re: Lift Anxiety
« Reply #3 on: November 10, 2021, 09:28:54 PM »
OK,
Tomorrow is a holiday and the weather should be nice.
I also seem to have a perfect alignment.
So with this blessing from the ancient Maya builders, I'd better get on with it.
14453-0
bigrockcandymountain
Re: Lift Anxiety
« Reply #4 on: November 11, 2021, 09:42:44 AM »
The alignment is favourable indeed.  You are probably in the middle of it right now so good luck.  Lots of wind on the way so you should get it tested in the next few days.
Astro
Re: Lift Anxiety
« Reply #5 on: November 11, 2021, 09:43:19 AM »
Awesome!
kitestrings
Re: Lift Anxiety
« Reply #6 on: November 12, 2021, 08:50:52 AM »
Hope it went well... some hellish winds here today.  ~ks
