Please can we maintain a civil tone and civil language?
I have removed a post that failed on both counts in its opening line.
Sorry. Just so everyone knows it was not about anyone here, but about my dis taste for the utility company.
So I will re type.
I I add a panel of 2-3 circuits. Feed that panel from grid tie inverters, WITH limiters. Then have a couple batteries feeding a separate inverter. I will basically have a couple circuits that will be fed from the mill. If the mill can not provide enough power due to low wind the batteries will make up the difference. Because of the limiting function it will always take from the mill first it it is available. If I do a good job designing and building this set up, hopefully the batteries will really only be used to help with start up current of the fridge and freezer. That should help keep my mill at a more stable speed. If a no wind situation happens, it will run for a little bit off the batteries and when they go dead, I will have a contactor/transfer switch that turns on a utility fed outlet, with a battery charger hooked up to it.
Now around here there is no lack of wind, but let's even say that half the time I am using utility power to charge the batteries and feed those couple of circuits. THE OTHER HALF THE TIME I AM NOT. That should be fully automated, simple and reduce my electric bill from day one. Obviously more batteries would be great, but I am not looking for power for days and I am trying to keep cost down to make the pay back time better.
For half the month I have turned the utility into the back up power and on those circuits I cut my usage in half.
It all starts with the mill however. So when I thought about all this at first I wanted a large one. Well cost was a problem. So when I started to lay out the parameters, I arrived at no smaller wire then #14 so I could pull about 15-18 amps. Any smaller and it was not practical for home use and larger was obviously going to cost more in every part need to make this system.
I am shooting for half the time it will be off grid. The avg for wind speed here is 15 mph. Obviously not all days have wind, but most do. Very very few still days or nights. If I can get it so that half or more then half the time I have those circuits off grid, I will build another one and remove a couple more circuits. But I know we have the wind more then half the time, so it all comes down to building a good set up.
In the end if the utility goes down, I will just throw a transfer switch and start the generator and power everything while charging the batteries.
Two of the biggest things are obviously the design of the mill and I have spent hundreds and hundreds of hours on my design. The second is I have to have a limiter on the inverters so it only draws what it needs from the batteries and no more then that. I have fumbled around and tried to figure out a way to make an independent limiter, but the light bulb has not gone off yet. I had a couple of thoughts on it, but they never fully turned into a plans.
I only want the batteries as almost like a capacitor in a way. And as long as there is wind, I want to turn the utility into back up power for those circuits.
Again sorry for swearing before (not really even a swear word), but I get a little.......... grumpy, when as I said "they only want to save the world if they can make money doing it".
