joe,
Thank you for this explanation. It's one I never would have thought or expected. In part I guess I just associate the idea that the copper moves at all with a vague understanding of eddy currents - something we're usually trying to avoid - and in part that I regrettably just don't have the background in theory.
I tend to look at this type of question in much simpler terms. There's no such thing as a free lunch, right, and we can vary some material choices & design elements, but in the end we're doing work. You can pedal the bike faster in a lower gear, or harder in a higher gear... that sort of thing.
brandnewb,
There was a fellow here for many years named Flux. He was brilliant, and experienced and kind and patient... and had a knack for explaining things. Unfortunately he passed away a few years ago. I still miss him, as others do, I'm sure. I looked quickly through a few of my bookmarks, and prints of discussion he contributed to - this was one:
"Increasing magnet strength, disc diameter and number of magnets does effectively increase power.
Cut in voltage depends on the rate of change of flux and the number of turns. You can get any cut in you want by altering the number of turns if all else stays the same.
Power eventually depends on the voltage and circuit resistance. you can only get more power by lowering the circuit resistance once you fix the cut in.
The way to lower resistance is to use thick wire, which restricts the number of turns. Stronger magnets, more of them and increased frequency are the things that let you get more volts with less turns.
Larger discs let you get more nagnet area in, you can do it with few magnets of large area or lots of smaller magnets but by adopting lots of smaller magnets you keep the turn length short and it is easier to get the same result.
Flux"
You can break it down to relevant the formulas... from Flux, or Adriaan, or Ed, or Hugh or the Dan's, but I think a lot of it comes back to these type of concepts, and much hinges on the goal(s) and available materials and skills/limitations to build.
Best, ~ks
