After almost 30 years I finally need to rebuild the stator and replace the magnets on the outer rotor. Some of the magnets cracked on the rotor and rubbed against the stator, cutting into the windings. It is a 16 foot diameter windmill built using Dan Bartman's book, Homebrew Wind Power. Attached are three pictures of the inner rotor, the stator and the outer rotor.
As the picture shows on the outer rotor, the upper magnet broke and jumped to the next magnet, causing the stator damage. After cleaning the loose coating and rust from the other magnets, I noticed that six other magnets have hairline cracks in them. So I plan on replacing all the magnets on the outer rotor. The magnet show swelling from the rain and snow.
The stator will also need to be rebuilt.
One interesting thing I noticed on the inner rotor is that there is no indications of the coating breakdown or rusting of the magnets, just some paint that flaked off over the years. The magnets were covered with grease and oil from the inner bearing that leaked out of the bearing seal. I am thinking that is what protected the magnet from rusting. I greased the bearing ever year. I plan on spraying some type of spray lubricant on the outer rotor magnets to see if that keeps the magnets from rusting. That will be part of my annual maintenance.
Another question I have is do I need to use the same N rating on both rotors. I presumed that I used N42 magnets as that what was used in the book to build the rotors. If I could find N50 or N52 magnets would that work? I use the mill for direct ac heating so cut in voltage isn't an issue. The magnets are 3 inches long x 1.5 inches wide x 3/4 inch thick. I haven't found any place to order this size. Can be special ordered, but I hate to see the cost. Anyone know of any other companies that I could look at?
I am almost 70 years old and if I can get another 5 or 10 years out of it before it breaks down again, I'll be fine with that. The blades are starting to show some wear but I hope they hold up for some more years. The gusting winds are steadily increasing ever year in this part of the country.
I never thought that it would hold up as good as it did. This is the first time I had any kind of failure. People comment that it is always turning and now they wonder what happened to it.
windy
