View full version: Newbies
  1. Sub 50 watt generator
  2. Furling Estimator
  3. HP required to turn 10ft wind generator
  4. Producing but need more help
  5. PM Alternator Battery Load
  6. build a DIY anemometer with datalogger
  7. Where do i start.
  8. 120v 5600rpm treadmill motor.. bit of guidence please.
  9. How to determine Wind Turbine Rotor RPM
  10. armature rewinding
  11. Heating for Illinois winter
  12. Older BP/Solarex panels
  13. Worth grid tie for 30 cents/kwh???
  14. meter question
  15. induction motor convertion question
  16. indirect evaporative cooling idea
  17. induction motor problem
  18. Give them a break!
  19. Charging a larger (amp/hour) battery bank
  20. logging with an anemometer? What and the How?
  21. Alternate Diversion Load
  22. 12V or 24v ?
  23. Where can I get 3 inch magnets for 17 footer
  24. Mold caulking
  25. Duck Bill Anchors
  26. Oz, Is everything OK?
  27. Liquid Lithium Chloride Absorption System Using Solar Energy
  28. Turbine design: tip-speed, cut-in, and # turns
  29. Re:-Question for Redrok Users (Sept 15 2007)
  30. Info on home building...
  31. Admin testing
  32. test
  33. test
  34. PM dc motor sources
  35. dc motors smart drive
  36. dc motor
  37. blade effiency for homemade vawt?
  38. low speed alternator
  39. Tower height
  40. Wind mapper
  41. wiring delema
  42. Question on towers/ couplings
  43. ???? converting windspeed to power out
  44. help with calculations please
  45. DC Motor as a generator
  46. replacing magnets in motor
  47. Hugh Piggot 6' Question
  48. Winding
  49. Another Newbie Question
  50. Is it possible?
