Author Topic: Winding  (Read 978 times)
alljamin
Winding
« on: September 08, 2009, 09:01:59 AM »
Hi all
Help !! I have been building Hugh Piggott,s 10ft, 24v, 3 phase,
June 2005 edition page49,
The magnets he used are n35,s & 17awg /2wire/75 turns
I have n42,s ? Can anybody help with wire size and number of turns
I am a little lost!!!
Thanks mark
« Last Edit: September 08, 2009, 09:01:59 AM by (unknown) »
Re: Winding
« Reply #1 on: September 08, 2009, 03:08:15 AM »
Going from N35 to N42 won't make a lot of difference. You can most likely use the same winding and increase the air gap a little bit and have more mechanical clearance.
You could probably manage with 70 turns and keep the same gap. I don't think you can gain enough space to use thicker wire.
« Last Edit: September 08, 2009, 03:08:15 AM by Flux »
alljamin
Re: Winding
« Reply #2 on: September 08, 2009, 03:16:33 AM »
Thanks Flux
Let you know the results
Cheers Mark
« Last Edit: September 08, 2009, 03:16:33 AM by alljamin »
DanB
    • otherpower.com
Re: Winding
« Reply #3 on: September 08, 2009, 07:38:44 AM »
If you wind very nice tight coils, you can fit #16 wire in there I think...  for 48V machines of that voltage and those magnets, with 12" rotors, I usually use 70 turns of #16 these days, but the coils need to be wound tightly.  #17, with 70 turns, will fit easily.
« Last Edit: September 08, 2009, 07:38:44 AM by DanB »
