Author Topic: COIL WINDING ISSUE  (Read 1338 times)
lglagasse
COIL WINDING ISSUE
« on: February 03, 2008, 12:29:21 AM »
I am making coils for the 17ft [old style] machine. My question is this. The correct coil should weigh 1.5 lbs. ea. my coil weighs only 1.25 lbs. ea should I make the center island smaller?? Coil seems to fit stator patern ok, seems if I smallen the island that would put less copper on the coil.
This is # 15 wire in two strands. I am winding this coil on a lathe so ma by I am winding tighter than by hand. If I continue with this trend I would only have about 13 lbs. of wire on this machine.
Great to hear from everyone all over the world. Keep up the good work
« Last Edit: February 03, 2008, 12:29:21 AM by (unknown) »
Re: Double posting
« Reply #1 on: February 02, 2008, 07:26:14 PM »
If I'm not mistaken, this is a "double-post" because you just asked the same question on another section.
People should reply to the other posting which has already received a comment.
Another point of etiquette: using UPPERCASE doesn't look very nice and is equivalent to shouting.
Thanks.
« Last Edit: February 02, 2008, 07:26:14 PM by SparWeb »
