Author Topic: Gen 2  (Read 1252 times)
fukenfooser
Gen 2
« on: October 22, 2005, 01:12:29 AM »
My second Gen to be-
Gen 2     I will be calling it.
Is a "Ametek" Unit
Only numbers on it:  290990F7
     799031-301  REV.   L (SING)
     OIA  (E56617)   116401-01
     30  V. D. C.   NOMINAL
Stamped on can :
                       160101-497 L
On Face with shaft :
                        11
                    DIELECTRIC
                       TEST
I hooked up to the only two wires coming out of the back face
Neg to white wire
Pos to Brown wire
Looking down at face with shaft
Turning clockwise
Put a 4 1/2" flywheel on it
Put finger in the in-side of fly-wheel, opening is 2 3/4"
Turn fairly fast with a 12 VDC marker light and FLUKE 23 Volt meter on DC V
Read 8+ VDC and lit light up easly!!!!!!!!!!!
yea!!!!!!
Can is 4" OD
4  7/8"  long
Picked it up today for $ 20.00 USD
Was that a fair deal?
ff
« Last Edit: October 22, 2005, 01:12:29 AM by (unknown) »
fukenfooser
Re: Gen 2
« Reply #1 on: October 22, 2005, 03:39:36 AM »
Reading from a board search for "Ametek"
I found this
" The 40 and 30 VDC Ameteks are not good enough for me, as you don't see much more than a few amps (max is like 4 I think) out of them."
Is this true?
Was $20. wasted on a learning experience?
Or am I going to have a mini gen that might charge a single 12V DC DeepCycle
In a wind storm only?
AnyBody Have an Opinion?
Please!
I am still searching for "Charge Controlling"!!
THANKS
FF
« Last Edit: October 22, 2005, 03:39:36 AM by fukenfooser »
Re: Gen 2
« Reply #2 on: October 22, 2005, 09:47:47 AM »
fooser;
I can tell you from experience that those smaller 30 and 40 volt Ameteks are basically just way to whet your appetite for a real mill! I very seldom saw much more than a couple amps from them.
If you had stumbled on and read my Diary on these you would have seen they are pretty miserable on output. They are quick and easy.
http://www.fieldlines.com/story/2003/4/3/75719/71862
46 watts at 900 RPM is pretty miserable but what you will get from the 30 volt units and not much more from the 40 volt unit.
« Last Edit: October 22, 2005, 09:47:47 AM by TomW »
