Author Topic: wind power water pump  (Read 3960 times)
mjbain
« on: November 19, 2005, 07:53:17 PM »
this home made wind mill i use to pump my water at my place in oklahoma,it uses compress air to lift water from my well to storage in my little trailer worked good
« Last Edit: November 19, 2005, 07:53:17 PM by (unknown) »
RobC
Re: wind power water pump
« Reply #1 on: November 19, 2005, 05:29:35 PM »
I would like to the same thing but not I'm not sure I how to to build the pump end. Is there any good info on this?
Thanks RobC
« Last Edit: November 19, 2005, 05:29:35 PM by RobC »
mjbain
« Reply #2 on: November 19, 2005, 06:29:38 PM »
frist is the deep of your well,second is the high you need to lift the water,third
is the water level in the well.
for ever two foot of lift you must be able to go one foot below the water level in the well.
if these figure will work on your well the rest is easy,just the air line from the
pump is tee into the pipe to your storage one foot for every two foot of lift need to get to your storage
pipe size depends on air volume,among of lift don't know of any formuls for this.
good luck
« Last Edit: November 19, 2005, 06:29:38 PM by mjbain »
Walt
« Reply #3 on: November 27, 2005, 08:21:44 PM »
mjbain
where abouts in OK are you located?
Walt
« Last Edit: November 27, 2005, 08:21:44 PM by Walt »
mjbain
« Reply #4 on: November 27, 2005, 10:10:48 PM »
south of ringwood,ok. right now i'm in condon,or recovering from a neck surgery,don't know how soon i'll be back to oklahoma
« Last Edit: November 27, 2005, 10:10:48 PM by mjbain »
