Author Topic: Mini gen Test Data  (Read 1057 times)
Mini gen Test Data
« on: April 08, 2006, 02:49:13 AM »
i've been working on a mini gen lately , and did some testing in front of a fan.
i got 2.29V dc @ 361 rpm with three  9 3/8  inch radius blades.
Then i hooked it up to a 1.2v NiMH battery.
it was putting 115 mA into the battery @ 263 rpm
thats 138mW
i expect it will do a lot better when i put the other ( 5 ) coils , on there.
as it is at the moment it is an 8 pole dual rotor machine (4.25"dia. ),with one of six coils .
mags are 7/8" dia x 1/2 ".
i'll post some pics later , i must say it looks pretty cool.
the coil isnt what i will be using later but i wanted to try it out.
it has 130 turns of #20 gauge, but i'm going for around 200 turns.
this is some data about the coils ,from my progam , i think i'll probably use.
  Gauge= 20  Wire dia. = 0.0340 inches  ohms per foot 0.0101500
coil od = 1.690 coil width = 0.462 coilid= 0.670
Final Diameter =                 1.690
Num turns per coil radius =      15.000
Number of turns per coil width = 13.588
total number of turns            203.824
wire length(feet)=               61.976
Single wound ohms per coil     0.629054 turns/coil= 203.82
Total ohms for one phase                     (2 coils)       1.258
Delta single wound line to line resistance (2 coils/phase) 0.8387
« Last Edit: April 08, 2006, 02:49:13 AM by (unknown) »
Re: Mini gen Test Data
« Reply #1 on: April 09, 2006, 05:48:09 PM »
below is the heart of the minigen , a 5 1/4 HD mtor bearing.
i've turned it around so  the platten holder faces outward.
you can see why later.
this  is how it was before i installed a cut  bicycle sprocket,and before i put the 7/8" dia magnets on there.those are 1/2" dia magnets .
this took around two hours to cut by hand
 This is the first time i broke them yestrerday, i didnt take a pic of the second time.
a little epoxy and good as new.
The blade hub came out cool . i cut the foam with a hot wire, and used two plattens from the HD to make a foam sandwich.
This is the finished closeup
Yesterday reminded me of a monty python movie where this guy built a castle on a swamp,that sank into the swamp  ,so he built another , that also sank into the swamp, the third one burnt to the ground , then sunk into the swamp , BUT the FOURTH ONE....you get the idea..
« Last Edit: April 09, 2006, 05:48:09 PM by willib »
weir pictures
« Reply #2 on: April 11, 2006, 02:30:17 AM »
the lake that it feeds into is much higher than it was earlier , the drop is now only about three to three and a half feet...
it was at least five or six feet before.
i calculated the flow at 708 cfm, its ten feet across and six inches deep over the dam
« Last Edit: April 11, 2006, 02:30:17 AM by willib »
