COME ON GUYS don't you all see that is a Solar wind concentrator with flow stabilizer and velocity augmenter to produce a steady wind without any turbulence.
From the left is the Solar initial pickup head ,then stored in the first tank and stabilized with the pipe to reduce the wind turbulence for a facto of 100,000,000 times, then it is passed to the tank where the wind velocity is augmented by a factor of 10,000 times, the whole apparatus is placed inn front to the wind mill turbine which has a diameter 0.98 of the diameter of the augmenter output, this turbine coupled to a 1,000 KWH generator.
And the cost is low, the greatest cost is the generator. that represents 93 % of the overall cost.
The warranty is good for 25 YEARS if installed by the home owner and 250 years if installed by a certified Solar Wind Installer.
JeeeeeSSSS !!
It is about time that you guys recognize a good design.
Nando
