Author Topic: Guy wire Terminating  (Read 4833 times)
BruceDownunder
« on: September 13, 2006, 10:24:17 PM »
Hello, This is in reply to smoggy 's diary posting . I used similar 7 strand hard tensile steel wire used mainly in the electrical line /pole guying practice.
It's hard to terminate ,you must first bend the wire as close as poaaible to the shape of the thimble. Reverse bending the wire in a vice where u want the two wires to meet. U then temporary bind this "neck" with strong fencing wire and now u have a "standing" side and a "terminating" end. unravel a single strand up to the neck of the thimble , bend it at right angle ,and start tightly winding it 7-8 turns. You can't cut this wire with pliers , so holding it tightly with pliers ,file a nick on the wire and gently move it back and forth til it snaps. Do this with the remaining 6 strands.
Practice on a couple pieces first--This is very hard work ,you need strong hands and patience.
cold gal the termination for rust protection .
Well after all that , I can't seem to bring my pic's of the terminating process across to this posting ---- so, go to my irc album and there's a couple pic's on the third llast page ,or thereabouts.
Brucedownunder
« Last Edit: September 13, 2006, 10:24:17 PM by (unknown) »
Re: Guy wire Terminating
« Reply #1 on: September 13, 2006, 06:26:13 PM »
here you go...............
« Last Edit: September 13, 2006, 06:26:13 PM by hiker »
BruceDownunder
« Reply #2 on: September 13, 2006, 07:13:23 PM »
Thanks for that Alaska. I think I loaded them into my photo uploads , but maybe I was too anxious in posting them .
ps if u's can't see much detail ,then you can enlarge them by going into my album and double clicking on the pic.
Bruce
« Last Edit: September 13, 2006, 07:13:23 PM by BruceDownunder »
Experimental
« Reply #3 on: September 15, 2006, 07:21:31 AM »
 Hello Bruce,
    Very nicely done and was just looking thru your picture files -- loved those pine blades and noted the tips cut back at about a 30 or 40 degree sweep!!
I do that on all my blades, they seem to run very quiet...
    Loved the views from your home and envy you !!
   Again, well done, Bill H......
« Last Edit: September 15, 2006, 07:21:31 AM by Experimental »
DanG
« Reply #4 on: September 15, 2006, 11:55:33 AM »
Heyas Bruce - a member noted a problem once cables were already flying...
What do you suggest to do once guy line has a load on it? Looks like something that might happen often...  Thanks in advance!
Smoggy's Diary: http://www.fieldlines.com/story/2006/9/13/05617/8415
« Last Edit: September 15, 2006, 11:55:33 AM by DanG »
BruceDownunder
« Reply #5 on: September 15, 2006, 09:40:29 PM »
Hi Dan .  Well, you couls rig a nylon rope or similar above the guy  termination , say , 6 feet , by opening up the lay of the rope (3 stranded) and wrapping this around the steel wore. make tis "wrap" about 2 feet, and put a hitch in the rope near where it leaves the bottom. wrap the top end of the "wrapping" with a couple turns of electrical tape .
Now form a bowline hitch where it leaves the bottom of the steel wire rope and attach a cumalong or similar block and tackle. tighten up your guy wire to take the tension and now you can terminate the steel wire rope ahile the mast is still guyed.- hope this makes sense.
Bruce
« Last Edit: September 15, 2006, 09:40:29 PM by BruceDownunder »
