Author Topic: oops  (Read 848 times)
pepa
oops
« on: January 27, 2007, 04:04:48 PM »
I finished the stator for the oddball and after it was poured I decided to add air vents in the center of the coils. Everything went great until I let the router slip and ruin a coil by eating through the wiring. On a regular poured stator the mistake would have ruined the stator, but with the design of the new one, the fix was easy. I was able to replace the coil in a couple of hours and every thing turned out  as if it had not been damaged. pepa
« Last Edit: January 27, 2007, 04:04:48 PM by (unknown) »
Re: oops
« Reply #1 on: January 27, 2007, 03:51:09 PM »
 Wax or silicon makes an easy job of that .I use plugs if thier made but silicon and a little waxed paper around the inside and save a little resin . Put just a dab on the wax paper strips and fill up the hole . Quite a bit to fill in the holes i guess but it pops right out if you leave holes in the fiber . It may be less time consuming to cut the fiber after its set and a little green.
« Last Edit: January 27, 2007, 03:51:09 PM by tecker »
RogerAS
Re: oops
« Reply #2 on: January 27, 2007, 04:34:28 PM »
Please tell us what those bolts in the center are for,(noticing the lack of on outer edge) Mr. Peppa
« Last Edit: January 27, 2007, 04:34:28 PM by RogerAS »
pepa
Re: oops
« Reply #3 on: January 27, 2007, 08:59:03 PM »
:hi Rodger, the bolts hold the stator in place and also are the adjustment for locating the stator in the air gap. http://oddball generator going together. have a good day pepa. thanks Tecker for the tip, i have done it both ways, but this time i got careless. pepa.
« Last Edit: January 27, 2007, 08:59:03 PM by pepa »
Re: oops
« Reply #4 on: January 28, 2007, 06:34:54 AM »
10.4 looks like a good job. That is much better than I could have done with a router . I tried to use a spirel cutter to dress up the outside with the same result ,cut and solder time .
« Last Edit: January 28, 2007, 06:34:54 AM by tecker »
