Author Topic: $5 2-state temp compensated ANALOG dump controller  (Read 18413 times)
elt
Re: $5 2-state temp compensated ANALOG dump contro
« Reply #66 on: September 29, 2007, 11:07:40 AM »
Hi Scott,
There's an oversized 5/16" hole off to the left to go onto the positive battery terminal and the left-most vertical cut electrically isolates the circuit.
Here's a picture I posted of the first probe. I cobbled the little sensor onto it and then potted it and coated it with plastic dip... which is the reason I had to build a second probe for debugging!
It works (now) and is well protected so I'll use it and keep the second as a backup.
Thanks again,
- Ed.
« Last Edit: September 29, 2007, 11:07:40 AM by elt »
