Author Topic: wind solar etc  (Read 4895 times)
bj
wind solar etc
« on: April 16, 2008, 10:03:45 PM »
    Is there any value in all of us reporting in the same Units?  The
only reason for the question, is that, all of the smart people are
from all over the globe.  Those conversion calculators are cheap.  And
there are probably things on the Net that are better.
    It would save the moderators time, and their time is an important
asset.
    But then again maybe they can do the conversions in a thought.
    Maybe this should have been in rants, if so, sorry Tom.
    bj
« Last Edit: April 16, 2008, 10:03:45 PM by (unknown) »
bj
Lamont AB Can.
Re: wind solar etc
« Reply #1 on: April 16, 2008, 04:37:04 PM »
Personally I like folks just blurting out in the manner they are accustomed . We'll let the bean counters worry about the rest.
« Last Edit: April 16, 2008, 04:37:04 PM by tecker »
kurt
    • website
Re: wind solar etc
« Reply #2 on: April 16, 2008, 05:31:36 PM »
personally i find it very irritating when someone uses nonsense units like amps per hour or watts per day etc.  you never know what kind of crazy math they used to come up with there numbers and anyone who blathers on about such units gets promptly ignored by me because there numbers are nonsense because they are not standard units like amp hour, watt hour or kilowatt hour. i can deal with both metric and standard units that is what conversion calculators are for but please use a unit that exists. and do try to not say watts when you mean watt hours even old hands do this and it just confuses the newbies....
« Last Edit: April 16, 2008, 05:31:36 PM by kurt »
valterra
Re: wind solar etc
« Reply #3 on: April 16, 2008, 09:03:56 PM »
I was looking at batteries today.  I looked all over the label, but I couldn't find the Ohm Hours rating.  Could you guys help me with that?   :-)
« Last Edit: April 16, 2008, 09:03:56 PM by valterra »
methanolcat
Re: wind solar etc
« Reply #4 on: April 16, 2008, 09:45:59 PM »
valterra
   On all the batteries I have ever run across the Ohm Hours rating is on the back side of the label, just peel it off to check it.
« Last Edit: April 16, 2008, 09:45:59 PM by methanolcat »
Re: wind solar etc
« Reply #5 on: April 17, 2008, 10:06:32 AM »
If you can't find that rating they have left Ohm and changed ownership, you only have them for a limited time.
« Last Edit: April 17, 2008, 10:06:32 AM by Flux »
TheCasualTraveler
Re: wind solar etc
« Reply #6 on: April 17, 2008, 10:12:16 AM »
  they grow up so fast...
« Last Edit: April 17, 2008, 10:12:16 AM by TheCasualTraveler »
Jedon
Re: wind solar etc
« Reply #7 on: April 17, 2008, 02:25:27 PM »
There has been some resistance to this form of measuring though :-D
« Last Edit: April 17, 2008, 02:25:27 PM by Jedon »
Ideal Fabrications
Re: wind solar etc
« Reply #8 on: April 17, 2008, 05:03:01 PM »
Sorry guys, but I have no idea watt your talking about...
« Last Edit: April 17, 2008, 05:03:01 PM by Ideal Fabrications »
Re: wind solar etc
« Reply #9 on: April 17, 2008, 05:54:27 PM »
Simple math.  If the variables are understood.
I am working on the equation.
Pleasing colors are always 10.
Trojan purple is about a 6, depending on who you ask.
White or Black are usually 9 or 2, depending on who you ask.
Mauve is obviously valued at 16.
Heavy is rated at 4 to 14, on a scale of 1 to 10.
Battery life is rated at between 4 and 18, on a scale of 1 to 10.
Some is 7, great is about 10, bunches is over 13, while a hole lot better than users claim is 22 or more.
"OK" almost works, sometimes.
"Not Bad" means it worked, once.
"As Expected" means pretty good, but not good.
"Good" is almost OK.
"High" is usually too much.
"Perfect" is almost good, but not quite, and considerably less than expected.
Butt their are sum variations.
« Last Edit: April 17, 2008, 05:54:27 PM by ghurd »
spinningmagnets
Re: wind solar etc
« Reply #10 on: April 17, 2008, 06:39:42 PM »
Electricians do it without shorts until it Hertz...
"Wait... what the hell is a gigawatt?!" -Marty McFly in BTTF
« Last Edit: April 17, 2008, 06:39:42 PM by spinningmagnets »
finnsawyer
Re: wind solar etc
« Reply #11 on: April 18, 2008, 09:01:37 AM »
No.  We could all agree to use the MKS system (meters - kilograms - seconds), but then you have to say good bye to watts, as the MKS unit for power would be joules/sec.  Wait a minute.  What's a joule, anyway?  As I said, no, so forget it.
« Last Edit: April 18, 2008, 09:01:37 AM by finnsawyer »
Re: wind solar etc
« Reply #12 on: April 18, 2008, 05:02:34 PM »
As long as they use some kind of standard unit and use it correctly, I can usually decipher it.  I always see posts listing energy in units of power and power in units of energy.  Amps at a voltage are fine for power, but amp hours don't make any sense, Joules for Power or Watts for energy don't make a lot of sense either without a time parameter.  It would be like saying I traveled at 3 meters per second without anything else and asking how far I went.  Similarly if I traveled 30 miles, how fast was I going.
Still many folks are just starting out and some of us, myself included of course, slip up from time to time.  Usually we can get to the bottom of it with a few questions and answers to help someone out or figure out what was going on.  I don't think ignorance or even sloppiness should be capital offenses.  Just have fun with this.  Rich
« Last Edit: April 18, 2008, 05:02:34 PM by richhagen »
valterra
Re: wind solar etc
« Reply #13 on: April 18, 2008, 06:56:25 PM »
I don't know if you guys are joking or not.  I was able to find my Ohm hours pretty easy.
I take the rpm of my genny and divide it by the hour of the day.  Then I take that number and plug it into an online calculator I found.  It tells you your estimated battery capacity (measured in Ohm deciminutes because it is metric but I think he's writing a standard version) based upon the lattitude of your tower.
I pretty much trust it because nobody would go through all the trouble of writing a web page if they didn't know what they were talking about.  I wrap my power cords around a ferrite core... 2 turns per amp and that usually allows it to run off of 12v.  That's on the guys website too.  No diodes or rectifiers needed.  My pc now runs off of 2 6v lantern batteries.  If I'm lying then tell me HOW CAN I BE posting if I'm lying???
« Last Edit: April 18, 2008, 06:56:25 PM by valterra »
bj
Re: wind solar etc
« Reply #14 on: April 19, 2008, 07:32:23 AM »
     Rich
    Good advice, thanks.  To all,  I needed a good chuckle this morning,
and I got it.
    bj
« Last Edit: April 19, 2008, 07:32:23 AM by bj »
bj
Lamont AB Can.
kurt
    • website
Re: wind solar etc
« Reply #15 on: April 19, 2008, 08:47:03 AM »
i have you beat my computer runs off a potato and i have a picture...
« Last Edit: April 19, 2008, 08:47:03 AM by kurt »
Re: wind solar etc
« Reply #16 on: April 19, 2008, 10:21:56 AM »
And it cooks itself with the heat from the screen!  Two for the price of one!  B^>
« Last Edit: April 19, 2008, 10:21:56 AM by DamonHD »
Re: wind solar etc
« Reply #17 on: April 19, 2008, 12:50:25 PM »
I plant potatos under my monitor.  It grows 2 for every one used.
I am saving the extra potatos to go off-grid.
Then buy an LCD monitor with the savings, doubling the production per potato used.
Watt potato, 2 potato, 3 potato, overunity...
« Last Edit: April 19, 2008, 12:50:25 PM by ghurd »
Re: wind solar etc
« Reply #18 on: April 19, 2008, 01:18:01 PM »
Shhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
« Last Edit: April 19, 2008, 01:18:01 PM by DamonHD »
Re: wind solar etc
« Reply #19 on: April 19, 2008, 01:28:39 PM »
Hi bj
 We are all in this for fun and to have little comedy centrals like this is cool.
 Beats bickering by megaohms.
« Last Edit: April 19, 2008, 01:28:39 PM by vawtman »
Re: wind solar etc
« Reply #20 on: April 19, 2008, 02:35:14 PM »
Too late.  Big oil offered me a bookoo-bazzillion dollars for the idea.
And I took it, like everyone before me.
US$, GBP, Marks, Euros...  No matter... Next week, starting on Tuesday at noon, they will all be know as "ghurds".
They gave me a post-dated check.
The guys who wrote the check (John Smith and William Jones) explained why this kind of transition can not happen on a Monday.
« Last Edit: April 19, 2008, 02:35:14 PM by ghurd »
valterra
Re: wind solar etc
« Reply #21 on: April 19, 2008, 08:25:27 PM »
You know,
Just a few postings of that picture in the right places, or actually showing someone how the potato is plugged into your PC, and suddenly there will be people in this world who swear they "know a guy" or "heard about a guy" who ran a computer with a potato.  Nobody will remember you specifically, and the source of the (mis)information will be lost over time.  Too funny. That's how that kind of thing gets started.
Kinda like the "hydrocarbon powered ECO-Vehicle" bumper stickers I bought from Glenn Beck.  You should see the stories about people getting interested in hyrdocarbons to save the earth.
I love that potato picture.  We should start a thread of people showing all the stuff they run off of potatoes.
« Last Edit: April 19, 2008, 08:25:27 PM by valterra »
spinningmagnets
Re: wind solar etc
« Reply #22 on: April 19, 2008, 10:18:54 PM »
Is this similar to making a battery with a lemon, a nail, and a penny? This picture is worth a kilo-word.
Whats the C20 rating on an average potato? After its is so drained it begins sagging when the hard drive tries to spin up, you can brew it into ethanol to power your back-up 1.1 Watt micro-generator:
http://www.bizjournals.com/sanjose/stories/2004/11/22/daily41.html
« Last Edit: April 19, 2008, 10:18:54 PM by spinningmagnets »
valterra
Re: wind solar etc
« Reply #23 on: April 20, 2008, 06:22:04 AM »
Similar, except that Kurt's been able to develop a way to simply plug directly into the potato - no nail or penny necessary.
« Last Edit: April 20, 2008, 06:22:04 AM by valterra »
Re: wind solar etc
« Reply #24 on: April 21, 2008, 10:22:05 AM »
Did any of you guys make the lemon battery in science class.  Why not a potato battery, it could open up a whole new avenue for Idaho farmers, solving the energy crisis.  I believe a tomato battery was in the works until it was suppressed by some conspiracy or other too.  No, wait, it IS the next big thing, that's the ticket, better get on board by sending me a hundred dollars now I have the secret formula for it developed by a person with a real PHD and scientifically proven to put out more power than the sunlight used to grow it.  It's posted on the internet, so it must be true.  Get on board now.   Rich
P.S. Note to the stupid, this is sarcasm, please don't actually look me up and send me a hundred dollars - there actually is no tomato battery in the works here.
« Last Edit: April 21, 2008, 10:22:05 AM by richhagen »
valterra
Re: wind solar etc
« Reply #25 on: April 21, 2008, 01:01:59 PM »
oh - darn it Rich!  I didn't read your entire posting until AFTER I sent the $100.  So go ahead and just "Return to Sender," okay?  Or better yet, can you just send me $100 back now?  You should get the one I sent in a day or so.  That'll speed up the process.
« Last Edit: April 21, 2008, 01:01:59 PM by valterra »
blueyonder
Re: wind solar etc
« Reply #26 on: April 21, 2008, 04:37:29 PM »
 watts a joule . well finnsawyer  its when too jentilmen wants a fight.
« Last Edit: April 21, 2008, 04:37:29 PM by blueyonder »
Re: wind solar etc
« Reply #27 on: April 21, 2008, 09:34:32 PM »
The check is in the mail. . . . . Rich
« Last Edit: April 21, 2008, 09:34:32 PM by richhagen »
finnsawyer
Re: wind solar etc
« Reply #28 on: April 22, 2008, 08:33:59 AM »
Ouch!  I know you are being humorous, but I can just see some Newbie equating a watt to a joule.
« Last Edit: April 22, 2008, 08:33:59 AM by finnsawyer »
elvin1949
Re: wind solar etc
« Reply #29 on: April 22, 2008, 02:06:12 PM »
  You 2 sound like my Daddy and my Uncle.
They sold the same 29 Ford back and forth to
each other raising the price by 5 dollars each time. One day someone else offered Daddy $15 more so he sold it.
  Uncle got mad,we was both getting rich till you sold the car to someone else.
  HAHAHA
Elvin
« Last Edit: April 22, 2008, 02:06:12 PM by elvin1949 »
