Author Topic: Starting to design my off-grid power system  (Read 1051 times)
Jedon
« on: April 17, 2008, 08:36:55 PM »
Construction on my off grid house will start any day now so I need to get some power going on site.
Eventually I would like to be as diversified as possible energy generation wise which will include PV, Solar water heating, microhydro and wind.
For now though here is the plan:
Currently owned:
  1. 6V golf cart batteries from Costco = 12V
  2. W HF PV kit with crappy charger, 3x15W panels.
  3. HP 6500W Onan gas generator
  4. W cheapo inverter, plus whatever inverter is in our travel trailer.
Plan to buy very soon:
6 more batteries to equal 48V
Outback MX-60 Charge Controller
Outback VFX3648 3600W Inverter
What else do I need?
Fuse block?
Some way to have the charge controller start the generator?
Plan to add a few months after that stage:
Harris 2 jet pelton wheel + Delco gen + rainjets + PVC etc/
8 Kyocera 200W PV Panels
Then in a couple years:
Otherpower wind
more hydro
solar water heating
« Last Edit: April 17, 2008, 08:36:55 PM by (unknown) »
Re: Starting to design my off-grid power system
« Reply #1 on: April 17, 2008, 03:03:03 PM »
jedon;
As far as that generator start bit is concerned, check the specs on that Outback inverter. I think it may have an auxiliary output you can program [with the Mate] to fire up the generator.
I also would suggest the Mate accessory for any Outback Inverter. It turns a "dumb" inverter into a pretty smart inverter.
Just a couple thoughts.
« Last Edit: April 17, 2008, 03:03:03 PM by TomW »
Jedon
« Reply #2 on: April 18, 2008, 10:51:24 AM »
Thanks Tom, I just looked online and found this:
AGS mode. Advanced Generator Start (AGS) Mode utilizes the AUX output found on FX inverters and is compatible with any 2 wire start generator. AGS allows the user to choose a variety of conditions that will start a generator by energizing the FX AUX output.
So I'll add a MATE to my list of must haves!
« Last Edit: April 18, 2008, 10:51:24 AM by Jedon »
« Reply #3 on: April 18, 2008, 11:08:03 AM »
Jedon;
Great choice! It really makes the inverters much more versatile.
« Last Edit: April 18, 2008, 11:08:03 AM by TomW »
