Electron Pump,
'Getting over the hump' as you call it, If you
have a watt meter or use a couple of multimeters
like I do occasionally getting the voltage and
the amps readout you might notice on a low battery
that it probably cuts in early but then it will
putting in a lot of amps, but then it brings the
battery voltage up quickly (my theory) once the
battery voltage gets up higher the charging rate
goes down (I've noticed that 6 volt battery paks,
with fairly large capacity is harder pedaling than
12 or 24 volt)
BTW I try to put this on 'hot list' so I don't
miss interesting feed back.
I'm really trying to do the flywheel to friction
pulley thing....David Butcher succeeds in doing
about 150 watts with his setup so I see no reason
why I can't do the same...but I keep an open mind
and if someone can convince me otherwise
I want something simple efficient and quiet...
I've got the belt and auto alternator...(someplace)
