Author Topic: quick blades-cut from a tablesaw  (Read 1755 times)
« on: December 13, 2009, 01:22:26 AM »
came across this while surfin....
this guy cuts his blades on a tablesaw--kinda crude--no twist--but a fast way to make blades.
shuold be good for a treadmill motor or simular..
i would go ahead and make a good leading and trailing edge.........
    http://www.youtube.com/watch?v=uT2y5JJ24f4&feature=PlayList&p=5709E0D3D313D314&index=0
« Last Edit: December 13, 2009, 01:22:26 AM by (unknown) »
Re: quick blades-cut from a tablesaw
« Reply #1 on: December 13, 2009, 01:28:11 AM »
forgot to mention--its a total of six videos.....
« Last Edit: December 13, 2009, 01:28:11 AM by hiker »
« Reply #2 on: December 13, 2009, 07:10:45 AM »
I watched that a few times but they don't show them flying do they?
« Last Edit: December 13, 2009, 07:10:45 AM by tecker »
« Reply #3 on: December 13, 2009, 03:31:15 PM »
with a little work--make a airfoil on the backside--front side you could
flatten out the blades torewards the tips with a rasp or belt sander..
 made my blades from fence boards-airfoil backside --flatten out towards the tips front..slotted plywood hub...its held up for a number of years..
simplex blades........
  http://www.fieldlines.com/images/scimages/1236/test_stand_mill2
« Last Edit: December 13, 2009, 03:31:15 PM by hiker »
imsmooth
« Reply #4 on: December 13, 2009, 07:11:34 PM »
How about with a chainsaw?
http://www.youtube.com/watch?v=yosQqhkdaDk
There is a tutorial here with several pages linked: http://www.mindchallenger.com/wind/wgpage15.html
« Last Edit: December 13, 2009, 07:11:34 PM by imsmooth »
« Reply #5 on: December 15, 2009, 01:18:32 PM »
In segment 3 I'd have also tilted the miter saw.  That would have done most of the hub shaping and minimized sanding there to make a symmetrical and clean hub.  ("Hour of sanding" says something was wrong with the initial cut(s).)  Also would have used a stop to do the lineup on the miter saw identically on all four cuts.
Could rough in an airfoil by doing the two cuts at different angles (so the training edge was nearly sharp - though still leaving enough for a guide) and then sanding the hump and leading edge round and the trailing edge closer to sharp.  Also putting a knife edge on the outer end (to throw the tip vortex out and "virtually lengthen" the blade) and sanding the leading tip spherical and flowing into the knife edge.  Of course all this gets done BEFORE the balance step.
I've thought about doing taper in a similar situation by doing an initial "point the trailing edge" cut then a second pass with a cam guide on the top of the board, working against a post while the broadly-pointed trailing edge works against the fence (or a low extension of it), to do twist.  But haven't done all the geometry to see if this works out.
« Last Edit: December 15, 2009, 01:18:32 PM by Ungrounded Lightning Rod »
taylorp035
« Reply #6 on: December 30, 2009, 08:06:19 PM »
I use a sawsal and it takes almost no time and I get the perfect shape.
« Last Edit: December 30, 2009, 08:06:19 PM by taylorp035 »
