Author Topic: Hello's , Howdie's and a bad stator ?  (Read 3390 times)
ShadeTree
« on: January 19, 2007, 09:50:00 PM »
 First off i'd like to say hello to all, Been read'n this here board for a good 4 years,  guess it was just before the change to the new forum that i stumbled into
this Fine Establishment. Seeking answers i was and answers i found (my thanks to all). in fact tho, over the years i might have done me too much reading,  after awhile all those answers seem to blend together and a mans head gets foggy.
 And that foggy head is what has lead to this post.
 i built a small generator out of the front spindle and rotor of a 75 1/2 ton chevy
mmm, musta been at least three years ago and right proud i was too, yes sir a right
fine look'n machine it was, darn near perdy to the eyes.  BUT as perdy as it was it
would barely light a single LED (i know,, i know, it were plum embaress'n) still is
now that i think about it..
Which brings me back around to the stator, 12 coils, awg 17, 41 turns, the rotors
have 16 1"x1"x3/16 neos each, the stator is 3/8 thick and the air gap total is 1/2 inch. 16th on each side of the stator.
now when ya hook a load on it it is tuff to turn the blades and forget getting any
speed up. the ressistance is unbelievable.   i'm guess'n i screwed up wiring the
coils together in the stator,
3 phase 4 coils per phase, trouble is i wired from the out lead to the start lead
out lead to start out lead to start on each phase  leaving me with 3 starts and
3 outs.   i have 2 pics uploaded i just can't find the "drop down box" to insert
them in this post..
Could i get one of you fellas to tell me if the wiring is where i went wrong ?
and if so how it should have been done ?
Thanks Much
ShadeTree
« Last Edit: January 19, 2007, 09:50:00 PM by (unknown) »
gordon01639
Re: Hello's , Howdie's and a bad stator ?
« Reply #1 on: January 19, 2007, 03:29:49 PM »
I'm a relative newcomer but it looks right to me, connect the three start wires together and each of the three out leads goes to a rectifier to convert to DC. There is loads of stuff on here about this just google "rectify three phase" there are quite a few drawings.
Gordon.
Wales in the UK.
« Last Edit: January 19, 2007, 03:29:49 PM by gordon01639 »
asheets
« Reply #2 on: January 19, 2007, 03:39:12 PM »
The total gap between the coils and the magnets is too much.
Plus, you might want to check the bearings and whatnot -- unshorted and this airgap should be easy to turn.
Having said that, each individual coil should be able to light up an led or a penlite.  I'd say that if you can't get the entire string to light more than an led, then you've got some of your coils cancelling out the others.
« Last Edit: January 19, 2007, 03:39:12 PM by asheets »
ShadeTree
« Reply #3 on: January 19, 2007, 04:07:19 PM »
Thanks Gordon and Asheets ?  for the replies,
Gordon wiring the ins together and running the
outs through a rectifier is how i get it to
light the led.
Asheets, ya just can't get the air gap any smaller,
we're talking a 16th on an inch,  i will agree that
the coils are canceling eachother, somewhere i read
about connecting out to out then in to in then back
to out, as i stated earlier i've read so much that
it all blurrs together.
before building a new stator (ole ShadeTree is a lil
light on pocket change)i want to be sure i get it right
next time
as far as the frame, rotors , bearings and all go it turns
fine when no load is applied, with the stator disconnected
it spins up well into the 5 , 6 hunderd range in 20 - 25
mph winds,  but if ya hook the load up it's a bear to spin
it by hand..
oh, i did take an extra coil (same as the others) and with
the stator removed held it between the rotors and at very slow
rpms registerd 1.7 volts (open).
ShadeTree <-- not only can't post pics but his sig is missing too
              ah, there's the sig..
« Last Edit: January 19, 2007, 04:07:19 PM by ShadeTree »
gordon01639
« Reply #4 on: January 19, 2007, 04:42:50 PM »
Hi again shadetree, I did notice that on your files the picture of the stator 1 of the number 3 coils gos to a number 2 coil, I'm sure you just drew it wrong and didn't wire this way but you never know sometimes  you just do what you see.
Gordon.
In the Welsh valleys.
« Last Edit: January 19, 2007, 04:42:50 PM by gordon01639 »
asheets
« Reply #5 on: January 19, 2007, 05:08:11 PM »
I must have misread that -- it thought it said that your airgap was .5 inches...
« Last Edit: January 19, 2007, 05:08:11 PM by asheets »
wil
« Reply #6 on: January 19, 2007, 10:26:43 PM »
Hi ShadeTree,
"have 16 1"x1"x3/16 neos each, the stator is 3/8 thick and the air gap total is 1/2 inch"
I think what asheets was saying is that a 1/2 inch air gap is a little much for 3/16 inch thick magnets.
I believe the rule-of-thumb for stator thickness is to use the same thickness as the magnet. So your stator should be closer to 3/16 of an inch thick.
Wil
« Last Edit: January 19, 2007, 10:26:43 PM by wil »
« Reply #7 on: January 20, 2007, 02:09:41 AM »
"!as far as the frame, rotors , bearings and all go it turns
it by hand.."
This seems to imply that there is not much wrong with the stator.
The only way to find out what is wrong is to do some logical tests.
You need to do these on the alternator and you will probably have to remove the prop.
Join the 3 starts, you have 3 leads (finishes) to play with. Turn the thing at a known speed by hand (120rpm is easy for counting) it should be perfectly free( you say it is)
Measure the AC volts between each pair of leads, should be the same.(meter on AC volts)
Now short all 3 leads, it should be a bear to turn and the drag should be smooth. Disconnect one lead and it should be hard to turn but you should feel it turn in discrete lumps.
If all these steps are ok then your alternator is working properly.
Connect the rectifier to the ac leads but leave the dc terminals open. It should still turn with no resistance and no signs of lumpiness.If you have any resistance or lumpiness then you have a scrap rectifier.
Now measure the dc out of the rectifier ( meter on dc volts), it should be 50% higher than the AC volts that you measured earlier. Short the dc connections and it should be stiff and smooth to turn. If it pulses it shows a rectifier problem.
Once you know the alternator is working properly it is time to see that it is matched to your prop.
Come back with that dc voltage out of the rectifier and the speed you turned it at and also details of your prop.
From your description you seem to have connected the alternator ok. Your 1/2" air gap should be ok. I am beginning to suspect a duff rectifier.
« Last Edit: January 20, 2007, 02:09:41 AM by Flux »
ShadeTree
« Reply #8 on: January 20, 2007, 07:07:20 AM »
Morn'n men,
Gordon,  yeah thats just a bit of an illusion
on that drawing, i did the drawing yesterday
built the stator years ago. it was just to give
an idea on how i wired the coils together.
Thanks for replying Flux, i've followed your
posts for a long time.  i think the rectifiers
can be ruled out as i have tried 4 different and
all new, cept for the one shown in the color pic
that was outta a car alt.  i have even had each
finish (out) with it's own rectifier and still
no difference.
i will take her apart and put the stator back in
to run the tests you suggest, also if i can get
one of my 12 pixel cameras to work i'll get a pic
of the blade,   it's 3 blade, each wing is 3 feet
long, 6 inches wide at the root, down to 3 inches
at the tip.
(that were no typo on the camera pixels)
it'll be days maybe longer tho before ole ShadeTree
can do these things, i have to wait for the weather
improve all my work is done outside, hence the handle
"shadetree"
i might have another pic that at least shows the blade,
if so i'll add it to my user files or if i can edit this
i'll add it here.
one more thought,  a man could turn that rotor 120 rpms
with a load on it or the leads shorted using the blades
for leverage, but it's gonna be TUFF. i was very supprized
at the power 32 of those magnets could produce, which
brings up another idea for a different day...
Thanks again all
ShadeTree
« Last Edit: January 20, 2007, 07:07:20 AM by ShadeTree »
ShadeTree
« Reply #9 on: January 20, 2007, 07:31:52 AM »
here's a couple more pics, to give ya
a better idea of the blade and general
construction..
and ya thought i was kid'n bout those 12
pixel cameras...
ShadeTree
« Last Edit: January 20, 2007, 07:31:52 AM by ShadeTree »
luv2weld
« Reply #10 on: January 20, 2007, 08:47:04 AM »
Did I miss what kind of load you are hooking to the output???
That will make a heck of a difference in how the rotor turns.
Ralph
« Last Edit: January 20, 2007, 08:47:04 AM by luv2weld »
ShadeTree
« Reply #11 on: January 20, 2007, 09:47:17 AM »
Hi Ralph,  naw i never really said what
the loads were,  hooking into a 12 volt
battery, or (but here's the kicker) just
putting a led inline after the rectifier(s)
is enough to drag it to a standstill..
and ya have to crank like heck to even
get a flicker out of the led. not cranking
as in high rpms as in over coming a braking
force.
i have a couple other lil mills made from
a 36vdc stepper and a 12vdc volt motor that
will blind ya if ya was to stare at the leds.
a lil more info on the stator wiring,
each phase was wired then set into the mold
seperately,  i can run current thru each phase
one at a time and the circuit completes.
to me it's like the coils are working against
eachother, but then i ain't certain <--understatement
ShadeTree
« Last Edit: January 20, 2007, 09:47:17 AM by ShadeTree »
maker of toys
« Reply #12 on: January 20, 2007, 11:32:34 PM »
mmmm.  rolls free with no load, lugs down as soon as a current path is established.
my suspicion:  the recifiers are connected improperly.
with no load, but the rectifiers connected, does it drag, or run free?
(yes, I read the part about 3-4 sets of rectifiers all behave the same.)
-Dan
« Last Edit: January 20, 2007, 11:32:34 PM by maker of toys »
ShadeTree
« Reply #13 on: January 21, 2007, 06:52:47 AM »
Morn'n all
    hmmm, it's to bad ya can't see all the
replies while yer reply'n, i have this short
& long term memory thing go'in on.
i can remember the gist's of the replys, just
have a lil trouble connecting names to them.
over the last few years i have spent days standing
out there trying different wiring combinations,
seems i do remember trying just one and then two
phases being wired and getting clogging both times.
actually a jittery electric feeling while turning
the rotor more than a clogging feeling.
i need to run thru all the steps i've done before
just to refresh my brain cells (shouldn't take long
there ain't but a few of'em).
if i end up making another stator i think
i'll do it the old way with the coil leads
exposed so each coil can be tested individually.
might be best for us thicker head types for
learn'n purposes..
Thanks Again, and i promise whilsts i'm out there
              stand'n in the blowing snow and cold
              loosing parts in the drifts i won't
              be cuss'n none of ya's .
ShadeTree
« Last Edit: January 21, 2007, 06:52:47 AM by ShadeTree »
luv2weld
« Reply #14 on: January 21, 2007, 08:29:57 AM »
ShadeTree,
Forgive me if I ask some stupid questions that you have already answered. Just want to make sure I'm reading this right. When you hook the 12v battery to the output, the rotor acts like you put the brakes on? Really hard to turn? Have you double checked the wires from the rectifier to the battery?? Negative to negative?? etc. Also you did check the battery to make sure it is good?? Other than crossed wires, or shorted rectifier there isn't anything I can think of at the moment that would cause the problem.
Ralph
« Last Edit: January 21, 2007, 08:29:57 AM by luv2weld »
ShadeTree
« Reply #15 on: January 21, 2007, 12:16:55 PM »
Hi Ralph,
    i'm hope'n it is a problem with
the way i wired the bridge rectifiers.
mostly cause it would save me building
a new stator .
looks like it's gonna be more than a
few days before i can do any trials.
if i ever get this one producing i will
build a slightly bigger one next time.
i don't need much power, i use between
140 and 150 kwh a month and thats with
an electric hot water heater and a well
pump, for years i kept my usage below
100 kwh a month and could get back to that
level if needed.
sorry Ralph i sorta wandered off there,
the battery isn't much, perdy much junk
i  just used it to complete the circuit.
but i get the same results when just trying
to run an led straight fron the gen, plus i
do not get enough power to light the led,
well it does light but only barely at very
high rpms,
as soon as i can i'll use the advice everyone
has given, see what happens and then report
back here.
ShadeTree <-- his bones and the cold do
              not mix well..
« Last Edit: January 21, 2007, 12:16:55 PM by ShadeTree »
ShadeTree
« Reply #16 on: January 22, 2007, 01:10:09 PM »
in the interest of science and furthering
mankind along the path to well where ever
they be go'n,  Shadetree braved the cold
sloppy mess and re-installed the old stator.
But with one tiny lil difference, i flipped it.
i'm happy to report i burnt out 2 10mm leds at
maybe 50 rpm if that many, so on to a lil bigger
test, a 12volt headlight, (ya need to remember
i am turning the alt by hand) now somewhere in
the 100 rpm range i get a RED glow in the
headlight, we're talk'n within a few more rpms
of actual LIGHT !
 since i can't turn it any faster by hand i have
mounted the headlight into the tail and will wait
for mother nature to spin it up.
 i get about the same voltage no matter which
direction i spin the alt. is this normal ?
all in all i think my main problem before was
the stator was backwards,   but then if that was
the case how come i get current no matter which
way the alt spins ?
the drag doesn't seem to be a strong as i
remember, tho it does increase as the rpms
go up..
Thanks for clearing up some of my confusion
on the coil wiring, i came very close to scrapping
the stator several times.. i can make alot of
improvements on the next one,  yup thats right
that old chassis still has another spindle and
rotor on it (:
ShadeTree
« Last Edit: January 22, 2007, 01:10:09 PM by ShadeTree »
ShadeTree
« Reply #17 on: January 22, 2007, 02:51:35 PM »
AH HA, found a problem that is
probbaly costing some power,
it appears i wired the coils
insideout, i reversed the starts
and ends,  i was going back over
this post
http://www.fieldlines.com/story/2003/9/11/84741/6758
which i had studied in the past,
even have 2 copies of it on disk
and still managed to wire the coils
end to start.
anyone have an idea how much loss
this is causing ?
ShadeTree <--maybe should call self Old Foggy.
« Last Edit: January 22, 2007, 02:51:35 PM by ShadeTree »
« Reply #18 on: January 22, 2007, 03:03:31 PM »
Flipping the stator should not matter. The direction of rotation shouldn't matter either. The voltage should be the same.
If the problem was not some kind of connection problem, I suspect there is still a problem.
All I can think of is the magnets are not correct on the rotors.  A WAG.
« Last Edit: January 22, 2007, 03:03:31 PM by ghurd »
« Reply #19 on: January 22, 2007, 03:23:19 PM »
Agreed, flipping the stator doesn't matter, reversing rotation doesn't matter, interchanging starts for finishes doesn't matter.
Now you have connected a lamp directly to the dc output it will not start in the wind (or lack of it from your pictures). If it does start it will blow the bulb.
These things are intended to charge batteries and you need a different control scheme if you use resistive loading with no battery.
« Last Edit: January 22, 2007, 03:23:19 PM by Flux »
ShadeTree
« Reply #20 on: January 22, 2007, 03:51:38 PM »
Hi Ghurd,   there still could be a probblem,
tho having the magnets placed right is the
only thing i am sure of.
Flux,  it's good to know reversing the starts
and finishes doesn't hurt output,
yes i know these are for charging batteries
and yup i have a charge controller that i will
use when the time comes,   the wind, yeah on
my lil test stand it doesn't get much unless
the wind is straight out of the south, then
being channeled between my shack and that line
of trees it gets perdy hairy,,   Truth is if
it blows that headlamp i'll be grin'n fer days.
ShadeTree
« Last Edit: January 22, 2007, 03:51:38 PM by ShadeTree »
Gary D
« Reply #21 on: January 24, 2007, 10:29:06 AM »
 Shade tree, if you have a turning signal bulb assembly handy you might be able to spin up the speed a bit. There is much less resistance there. With a car headlight, you have quite a bit of heating resistance before it lights up(making it harder to turn up to speed). If you do use the test stand as you've suggested, make sure it's weighted down (anchored down)so it won't tip over when a gust smacks the blades!
 The thought occurs that you might have had 2 starts(in's) and one finish(out's) connected before(or the reverse). Possibly you got them correct when you ran your tests this time(just a thought). Not sure how that would react, but think that would be an issue.
 I too watched Gunsmoke quite a few years ago...Festus was a nice guy, liked fishin' as I recall...   Have fun, play safe!   Gary D.
« Last Edit: January 24, 2007, 10:29:06 AM by Gary D »
ShadeTree
« Reply #22 on: January 24, 2007, 01:09:33 PM »
Hi Gary D,
   oh yeah, the mill has been on
that stand for 3 years,  it did tip
over one time yup that were 2 years
ago. had a lil tornado pass by,
 the legs (3) cover more ground than
the pics show plus i have 2 couple
hunderd pounds of steel over them.
legs look sumthin like this..
welp that ain't gonna work, i tried
do'n a lil keyboard art to draw the
stand, but it keeps scrambling on
post..
on the wiring, all the outs are grouped
together as are the ins,  it is possible
i had them hooked to the bridge rectifiers
wrong, tho over the years i had tried so
many combinations i shoulda had it right
at least a few times .
i know it has been stated that flipping
the stator should not make any difference
but at the same time i read the "how to"
on building a stator for the 10 foot mill
and in it it states to be careful to lay
the coils in the mold the right side up.
just to be on the safe side next time i
will follow that stator guide to the
letter,  tho right now i'm working on my
"riding battery charger/generator" nut'n
like riding the power to were it's needed..
Agree on the Festus,  a lil rough around
the edges but good people..
ShadeTree
« Last Edit: January 24, 2007, 01:09:33 PM by ShadeTree »
« Reply #23 on: January 25, 2007, 10:44:59 AM »
That comment about laying the coils the right way up means that you keep all the coils the same way. If you put the lot all in the other way but they are ALL the same way then it doesn't matter, that is what flipping the stator would be the same as.
Placing one coil upside down is the same as reversing the start and finish on a correctly placed coil.
I am sure much of your trouble is in the refusal to use a battery as a load and in the extremely low (useful) wind at your test site. Lamp loads are difficult to start in a decent wind area as you are in stall from the start.
At present all indications are that things are working properly if you can light a lamp by hand cranking.  If it doesn't start, remove the lamp, let it start up to a sensible speed then connect the lamp and see what happens.
« Last Edit: January 25, 2007, 10:44:59 AM by Flux »
ShadeTree
« Reply #24 on: January 25, 2007, 11:59:38 AM »
hello again Flux
   i agree the mill is working now,
that is why i moved on to work on my
backup battery charger.
"" I am sure much of your trouble is
the start. ""
What refusal ?  i always figured if
i could spin it by hand and lite a
headlight i would know it was working.
being in a low wind area makes it
alot safer to work on,  those blades
when they do catch the wind spin up
fast and have enough mass behind them
to kill.
it gets perdy spooky standing right
behind those blades when they are cranking
6 or 7 hundred rpm,,   even when they are
turning slow it can be quite painful on
the head (trust me i know).
Now , so ya can flip the stator and as long
as the coils were placed and wired correctly
it will work as well either way ??  so then
by flipping it you would be reversing the
"ins & outs"  <-- so it doesn't matter if
the ins come from the inside of a coil or
the outside loop ?  somehow that all just
doesn't register with me..
i know now from the replies that i did
wire the stator going clockwise "in" to
"out" i had gotten my ins and outs confused,
i plan on building one more genny only
doubling the magnet size and maybe 60
turns of awg17,  i already have a set
of 10 ft blades that were to go on the
mill we have been discussing but i don't
believe it produces enough juice to be
tower werthy.
ShadeTree <-- a poor hermit kinda guy who
              lives a no-frills lifestyle.
              a mid-sized genny a few solar
              panels, a backup riding-
              charger and he gonna tell the
              power company where to go..
« Last Edit: January 25, 2007, 11:59:38 AM by ShadeTree »
