Author Topic: Help! With solar  (Read 815 times)
Rik
Help! With solar
« on: August 05, 2007, 11:36:31 PM »
I'm preparing to add solar to my home. I'd like it to suplement my existing heat, I can't put in a wood stove so I have propane. I am thinking about 2 45watt panels and 6 golf cart batteries. 6 VDC, 220 amp/hours. I'm trying figure out how long this setup with a full charge will power a 450 heater (assume running costant)I can also charge batteries with grid power if needed, Our Electricty is cheap, Our propane is not.I live in Northern NV. 7200 elev. I've done what I can making the house efficient but not a lot can be done short of shelling out more than I have for an electric furnace.
Thanks,
Rik
« Last Edit: August 05, 2007, 11:36:31 PM by (unknown) »
wdyasq
Re: Help! With solar
« Reply #1 on: August 05, 2007, 09:08:31 PM »
PV panels to resistance heating or even to a heat pump is not an efficient method of heating.  Check out:
http://builditsolar.com/
If you are in a high sun area and have a properly built and oriented house you should need little more than solar heat. If properly designed, it can probably be passively heated.
« Last Edit: August 05, 2007, 09:08:31 PM by wdyasq »
AbyssUnderground
« Reply #2 on: August 06, 2007, 05:27:56 AM »
With that setup you can run the heater for less than 1 hour per day. Its just not worth trying to run a heater from solar PV.
Like wdyasq said, you're better off using solar heating.
« Last Edit: August 06, 2007, 05:27:56 AM by AbyssUnderground »
Rik
« Reply #3 on: August 09, 2007, 05:50:52 PM »
Thanks for the replies, I'm not sure solar heating will help much at 30 below though. I just wat to cut the propane bills a bit.
« Last Edit: August 09, 2007, 05:50:52 PM by Rik »
