Author Topic: PVC Blade Question  (Read 823 times)
Baling Wire
PVC Blade Question
« on: September 16, 2007, 03:11:27 PM »
about shaping the leading and trailing edges?  In particular, should one leave the
"normal" curvature of the pipe intact either for the upper or under side of the airfoil; or shape both the upper and under surfaces to a midpoint?  Pipe is 18"
diameter, and I'm wanting to make a 4 1/2' prop.
BW
« Last Edit: September 16, 2007, 03:11:27 PM by (unknown) »
Re: PVC Blade Question
« Reply #1 on: September 16, 2007, 04:15:47 PM »
You can probably leave the inner surface more or less intact and treat it as though it was the flat surface of a Dan type profile bent into a curve. It would probably work just as well if you made it symmetrical about the centre. The main thing is to have the thick bit about 30% back from the leading edge, a sharp trailing edge and a reasonably worked curve down to the leading edge with a small nose radius.
Whether you work from the inner surface or the mean line will affect the angle that you need to cut the section at.
If you want to be clever about it you can almost certainly find details for NACA sections with curved mean line but you probably have too many variables to hope to get  the results you need by other than inspired guess or trial and error. The pitch angles ( based on the line joining Le to Te ) will be very different from those required by the usual flat Clark Y sort of shaped blades.
This may give you some sort of idea.http://www.thebackshed.com/Windmill/articles/ChineseBlades.asp
« Last Edit: September 16, 2007, 04:15:47 PM by Flux »
Baling Wire
« Reply #2 on: September 20, 2007, 08:15:56 AM »
Thanks! Flux:
Looks like a good helpful link.  I'm still researching but will have the Saw and stuff out soon.
BW
« Last Edit: September 20, 2007, 08:15:56 AM by Baling Wire »
