Author Topic: RPM vs. blade diameter and pitch  (Read 1029 times)
windexperimenter
« on: April 23, 2009, 09:07:52 PM »
I would like to know if there is a mathematical method for calculating RPM's based on blade diameter and pitch for a given wind speed.
Or if a chart is available, that would help.
« Last Edit: April 23, 2009, 09:07:52 PM by (unknown) »
Re: RPM vs. blade diameter and pitch
« Reply #1 on: April 23, 2009, 06:41:07 PM »
Yes there are two very usefull blade calculators:
both are very good
http://www.alton-moore.net/wind_calculations.php
http://www.warlock.com.au/bladecalc-abstract.htm
..Bill
« Last Edit: April 23, 2009, 06:41:07 PM by willib »
« Reply #2 on: April 24, 2009, 12:59:42 AM »
Yes the calculators predict optimum speed on load. Unless you match the prop to the generator you will see 3:1 variations in speed at least.
« Last Edit: April 24, 2009, 12:59:42 AM by Flux »
windexperimenter
« Reply #3 on: April 24, 2009, 11:12:40 AM »
Thanks for the help guys.  I can already see that my design will need a little revising.  Or I will need to talk the wind gods into maintaining wind speed of 25mph. LOL
« Last Edit: April 24, 2009, 11:12:40 AM by windexperimenter »
« Reply #4 on: April 24, 2009, 12:05:00 PM »
..menter;
Well, if you discover how to pull off the later option, please post the process that works.
« Last Edit: April 24, 2009, 12:05:00 PM by TomW »
