Author Topic: 12 volt rv light bulb 24v bank?  (Read 2098 times)
greenkarson
« on: April 25, 2009, 01:16:37 AM »
have a 24 volt battery bank. What will happen if I use 12 volt rv light bulbs will they burn out right away or will they work?
« Last Edit: April 25, 2009, 01:16:37 AM by (unknown) »
Re: 12 volt rv light bulb 24v bank?
« Reply #1 on: April 25, 2009, 01:18:32 AM »
Bit of both, how long is right away?. You may get a few seconds of light if that suits your needs.
On a practical basis it doesn't work but partly depends on the type of bulb. Filament lamps will only last seconds, fluorescent will probably blow the inverter instantly or in seconds. Led may run overloaded for some time depending on the chosen current and margin of overload rating of the resistors.
« Last Edit: April 25, 2009, 01:18:32 AM by Flux »
kurt
    • website
« Reply #2 on: April 25, 2009, 01:48:57 AM »
if it is just an incandescent bulb just wire 2 of them in series for 24v will work fine....
« Last Edit: April 25, 2009, 01:48:57 AM by kurt »
Madscientist267
« Reply #3 on: April 25, 2009, 09:50:17 AM »
dont forget "as long as they are identical"... if not, the lower wattage bulb will see more voltage across it and burn out sooner (if not instantly)
« Last Edit: April 25, 2009, 09:50:17 AM by Madscientist267 »
Opera House
« Reply #4 on: April 27, 2009, 09:08:39 AM »
There are switching regulators  that will convert down to 12V.  You can often find 28 to 12V VICOR modules on ebay cheap.  They work fine down to about 17V on the input.  A PWM speed control can also be used as long as the lamp is incandecent, NO LED.
« Last Edit: April 27, 2009, 09:08:39 AM by Opera House »
