Author Topic: RPM vs Power of your Turbine.  (Read 1246 times)
theiceman
« on: June 14, 2009, 08:47:30 PM »
Hello, I was wondering if someone could submit an xls of the output of their turbine. (RPX/W) it would be even better if you have one with amps and volts as well, thank you very much.
« Last Edit: June 14, 2009, 08:47:30 PM by (unknown) »
SDSUMetalHead
Re: RPM vs Power of your Turbine.
« Reply #1 on: June 15, 2009, 08:07:58 AM »
I have tried putting together a spreadsheet like this from some of the pages I have found on this site. Find my posting about my project and I have a link to a spreadsheet I started. I wish I could get more help on that because I think it would be a good learning instrument.
« Last Edit: June 15, 2009, 08:07:58 AM by SDSUMetalHead »
« Reply #2 on: June 15, 2009, 09:56:56 AM »
Battery at about 13.7V.
RPM 500 = 0W
RPM 700 = 0W
RPM 800 = 1W
RPM ~1500 = 22W
It looks like a flop?
However it is good enough to question the accuracy of the readings because the diameter is 25.5" and the wind speeds at the various outputs.
I see no relevant information with only RPM and power output values.
« Last Edit: June 15, 2009, 09:56:56 AM by ghurd »
« Reply #3 on: June 15, 2009, 03:56:41 PM »
If you search through postings I've made over the years you would find some of mine.
The first of a small axial-flux (the first I ever built), and the second is a big motor conversion:
I put the things into a lathe, which turns them while I measure the voltage, current, speed, etc. output.
« Last Edit: June 15, 2009, 03:56:41 PM by SparWeb »
