Author Topic: Inexpensive Amp gauge  (Read 3089 times)
(unknown)
« on: February 16, 2010, 12:41:00 PM »
I've been needing a amp gauge to mount near my controller and I seen one on eBay for less than $5 shipped to my door. About a week later it arrived so I went out to test and play with it. I connected it to a 4 amp DC light and it pegged the 20a meter. It was connected proper but it had no shunt resistor.
I tested resistance of the meter and it ended up being 75mV.
Now I needed a shunt.
I had a piece of #12 copper wire (and with help) was able to determine the spacing of the meter leads to solder to this piece of 12ga wire. Here's how it went:
#12 is 1.588 / 1000'  0.001588 ohms / foot
75mV / 20A = 0.00375 ohms
.00375 / 0.001588 =
2.36', or 28.34" space between leads of the amp meter soldered to the #12
I used my HF meter to check the amps of a DC source and compared that to the meter reading on my analogue DC amp meter. They matched almost exactly at 4 amps.
Close enough to see how many amps my 5'7" dual rotor is putting into the battery.
Cheap and effective.
(Thanks Glen....)
Fused
« Last Edit: February 16, 2010, 12:41:00 PM by (unknown) »
Re: Inexpensive Amp gauge
« Reply #1 on: February 16, 2010, 02:45:03 PM »
Looks Great!
« Last Edit: February 16, 2010, 02:45:03 PM by ghurd »
tanner0441
« Reply #2 on: February 17, 2010, 11:28:01 AM »
Hi
I bought a 15A version of that meter and it doesn't need an external shunt. I have it with a volt meter mounted on a dead inverter case. I find it very useful especially if the voltage or current reading is unstable, you can see the needle moving where a digital meter looks like a fruit machine.
Brian
« Last Edit: February 17, 2010, 11:28:01 AM by tanner0441 »
Fused
« Reply #3 on: February 17, 2010, 06:05:44 PM »
Hi Brian
The Ebay seller made no mention that this gauge would not work as ordered.
I was shocked when it buried the needle with 4 amps going through it.
Thank God for smart fellas like Ghurd, he's the man. He walked me through it all.
Fused
« Last Edit: February 17, 2010, 06:05:44 PM by Fused »
Tritium
« Reply #4 on: February 17, 2010, 08:55:00 PM »
Yea I bought a 400 amp meter from e-bay to find out it was a 50mA meter with a 400 amp scale. Needed a 500A shunt to make it work.
Thurmond
« Last Edit: February 17, 2010, 08:55:00 PM by Tritium »
