Author Topic: IRC user information  (Read 10977 times)
Re: tom i need help
« Reply #33 on: August 19, 2007, 08:04:23 AM »
Pepa maybe do a practice winding of a couple turns and upload a pic.
 I did a diary entitled( 2ph stator winding)in my files.
 Learned alot from that.Thanks again guys.
 Have fun
« Last Edit: August 19, 2007, 08:04:23 AM by vawtman »
Re: tom i need help
« Reply #34 on: August 19, 2007, 01:52:24 PM »
Hi Pepa,
Maybe Zubbly can chime in because you'll only get 2nd hand information from me.
You say 'if it worked for Tom's generator...'; I remember Zubbly explaining to me how it -was- a problem for Tom's generator and which took him a while to figure out what went wrong; the links to the two drawings explains it all; I suggest we learn from other people's mistakes; Z has made a quite a few and learned a lot doing it and solving the problems; no need for you and I to repeat the same mistakes. In fact, I -was- going to make the same mistake as you and Zubbly, but thankfully he spotted my error in time and corrected me.
The solution he used in Tom's generator was to rectify each phase individually.
In your case, however, it looks pretty easy to remove just the two windings of one phase and correct the stator, without too much rework/hassle. In that case, you'd have the option of wiring for star, delta and even rectify the phases individually.
Regards,
« Last Edit: August 19, 2007, 01:52:24 PM by dinges »
Re: tom i need help
« Reply #35 on: August 19, 2007, 01:54:15 PM »
You did a perfect job explaining things, Oz.
Sorry for the late reply to this thread but I have been away for the weekend.
« Last Edit: August 19, 2007, 01:54:15 PM by dinges »
Re: tom i need help
« Reply #36 on: August 19, 2007, 03:03:17 PM »
Peter
 I wonder what zub thinks of the 12/36 winding.If he chimes in.
 Pepa has large slots.
« Last Edit: August 19, 2007, 03:03:17 PM by vawtman »
pepa
Re: tom i need help
« Reply #37 on: August 19, 2007, 06:35:17 PM »
thanks Peter, you did good. my mind had one of its regular blank spots. pepa
« Last Edit: August 19, 2007, 06:35:17 PM by pepa »
