Author Topic: miniature diesel generator "Generette"  (Read 614 times)
Muffloj
« on: December 22, 2004, 05:52:49 PM »
   I thought some of you might find this interesting
http://www.pentaclemagazine.org/php/print.php?sid=1155
  Found that while looking at these batteries
http://www.pacificsites.com/~brooke/BA5590.shtml
« Last Edit: December 22, 2004, 05:52:49 PM by (unknown) »
Re: miniature diesel
« Reply #1 on: December 22, 2004, 11:08:23 AM »
whats witchcraft have to do with engines?????????????
thats where your first site points to......
no thanks!!!!!
« Last Edit: December 22, 2004, 11:08:23 AM by hiker »
phil b
« Reply #2 on: December 22, 2004, 11:41:57 AM »
I see batteries on the second site. No engines. Am I missing something?
« Last Edit: December 22, 2004, 11:41:57 AM by phil b »
Phil
Lettuce
A VW Jetta engine, eye of newt and wing of bat
« Reply #3 on: December 22, 2004, 01:14:33 PM »
A little Hocus Pocus and you get
http://www.tectonica.net/products.html :)
Personal Electrical Power Generation Solution
The PGS is a man-portable power source for use by individual soldiers. The device overcomes the limitations of chemical batteries by providing electrical power from a generator driven by a combustion engine running on logistic fuel. It also is capable of storing electrical power.
The PGS has minimal visual, thermal, acoustic and olfactory signatures under any operating mode.
The Pagen site was just a newswire feed.......
« Last Edit: December 22, 2004, 01:14:33 PM by Lettuce »
« Reply #4 on: December 22, 2004, 02:58:59 PM »
Some people claim that they really run on black magic.  B-)
Seriously, though.  The SITE may be a witchcraft site, but
the ARTICLE is about a (recently completed?) military
project to design a miniaturized diesel generator.
It's intended to replace the $100 disposable one-day-capacity
battery used to power the electronic warfare gear carried by
modern US soldiers.
Personally I think it's a rotten idea for soldiers.  Batteries
are silent, while this thing, though "significantly quieter" than
a diesel model airplane engine, is not.  Bad for stealth missions.
Diesels emit exhaust, which can easily kill a soldier in an enclosed
environment.  Diesels create several times as much heat energy as
output power, making the soldier a much bigger IR target and also
imparing his efficiency in a hot environment.  Diesel exhaust leaves
a characteristic odor that lingers, again making him more detectable,
both where he is and where he has been.  And so on.
If they want to replace the single-use batteries with something
refuelable, liquid-fueled fuel cells would, IMHO, be a much better
choice.
But for other uses than powering the wearable gear - like a
man-portable power supply for equipment that gets set up in
remote locations - it makes good sense.  And for non-military
applications ditto.
« Last Edit: December 22, 2004, 02:58:59 PM by Ungrounded Lightning Rod »
