The Chena hot spring near Fairbanks, Alaska has a lot of 165F (74C) shallow geothermal water within easy reach, and also plenty of 40F (4C) surface water to use for a condenser.
Since water boils at 212F, they decided to try a new design that uses a common R134a refrigerant in a secondary loop that boils and condenses within these parameters to power a conventional high-RPM turbine. The turbines not only draw power from the pressure supplied to their inlets, they also derive significant power from the partial vacuum drawn by the condenser.
The hot water is drawn from a 700 ft well, and discharged to the surface. The cold condenser water is supplied without a pump from an elevated natural reservoir and it is also discharged to the surface.
Their previous power supply was a bank of Diesel-generators that consumed an average of 1,000 gallons of fuel a day. The diesel power was provided at $0.30/Kwh, and the cost of power from new plant is $.07/Kwh.
The $2.2 million project is rated at 400 Kw, and was put together in two 6-month construction cycles due to severe winters. Its modular nature allows for easy expansion as the city's electrical needs increase.
I believe this is a major development, because the lower heat requirement of this type of plant makes solar-generated electricity more cost-effective. Also, the major components are readily available as they were adapted from existing large refrigeration components by the Carrier corp.
Nuclear power (though improved) is still effectively blocked, and the new "cleaner" coal plants take about 5 years to build.
http://www.yourownpower.com/Power/#How%20it%20Works%20...
http://en.wikipedia.org/wiki/1%2C1%2C1%2C2-Tetrafluoroethane
