Author Topic: Could this work??  (Read 1015 times)
mccoyxx
Could this work??
« on: November 16, 2006, 11:50:51 AM »
Hello..I am new here and just had a question I had to ask...well I know a solar panel gets its charge from the sun(UV rays)...so my question is ..could someone mount solar panels in a room with a tanning bed since thats sup. to be almost the same as the sun..like if the room is  small and the beds close to the wall...could you mount the panels like against the back wall where the crack is between the upper and lower section of the bed and the ends where the most intense light escapes when its in use...I know this wouldn't be very practical or help much ..but, every little bit counts!! and just think ..what if you own a tanning saloon or even better..what if your neighbor does and would let you put your panels up!! ...this may in no way be a possibility ..but, I just had to know!! RSM
« Last Edit: November 16, 2006, 11:50:51 AM by (unknown) »
drdongle
Re: Could this work??
« Reply #1 on: November 16, 2006, 05:28:30 AM »
Sure it will "work" but it's not worth the effort. alot of work and money for a very small return.
« Last Edit: November 16, 2006, 05:28:30 AM by drdongle »
DaveW
« Reply #2 on: November 16, 2006, 05:30:28 AM »
  Once again, no.
« Last Edit: November 16, 2006, 05:30:28 AM by DaveW »
