Author Topic: Area of a solar panel  (Read 1981 times)
Daggs
« on: April 06, 2006, 07:20:03 PM »
How big are solar panels in area?  Anyone have a spreadsheet or link that relates wattage to area?  Thanks.
« Last Edit: April 06, 2006, 07:20:03 PM by (unknown) »
Daggs
Re: Area of a solar panel
« Reply #1 on: April 06, 2006, 01:39:49 PM »
Here's the reason I'm asking.....
I hectare = 2.5 acres, roughly.  How manykilowatt hours would this bank produce?
Someone check my math for me....
Raw sunlight hits the earth at about 1.38kw/square meter.  I hectare = 10,000 square meters.  Efficiency of a solar cell in turning raw sunlight to electricity is .20 (??).  1 hectare of solar cells gives about .767kwhs of power.
Multiply this by the average suntime per day, and the number of sunny days per year for Albuquerque (where I live) and I get....
.767 x 10 x 300 = 2300kwh per year.
Does that sound right?
« Last Edit: April 06, 2006, 01:39:49 PM by Daggs »
Nando
« Reply #2 on: April 06, 2006, 03:00:23 PM »
A more practical values
Solar Insolation ~ 1.0 KW/m^2
  1. 47 acres = 1 hectare = 10,000 M^2
  2. KW * 6 hours *0.17 efficiency = 10.2 MWH/ day
  3. 2 * 365 days /year = - you do the calculation.
Nando
« Last Edit: April 06, 2006, 03:00:23 PM by Nando »
Nando
« Reply #3 on: April 06, 2006, 03:03:24 PM »
correcting display
[new] Re: Area of a solar panel (3.00 / 0) (#3)
by Nando (nando37-at-comcast-dot-net) on Thu Apr 6th, 2006 at 03:00:23 PM MST
~~~ 2.47 acres = 1 hectare = 10,000 M^2
~~~ 10,000 KW * 6 hours 0.17 efficiency = 1.02 MWH/ day
~~~ 1.02 MWH
Nando
« Last Edit: April 06, 2006, 03:03:24 PM by Nando »
« Reply #4 on: April 06, 2006, 03:13:04 PM »
First, why confuse measurements? 1KW is usually used as the peak solar insolation for a square meter.
What the heck is a hectometer?
Yea, I do know, but 'hectare' (1km^2) and 'solar' are not found on any chart I've ever seen.
Next, there are 3 main types of solar electric panel. Somewhere around 7%, 15% and 17%.  Amorphous, multi/poly crystaline, single/mono crystaline.
Get into NASA type stuff and it could go 40+%.
Now get into wasted area. Space between cells. Space between areas. Etc.
Then heat/temp. etc.
It would be best to use the manufacturer's specs and work backwards.
Mono is best, multi is a close 2nd, amorph is a far 3rd (and won't last as long).
« Last Edit: April 06, 2006, 03:13:04 PM by ghurd »
antw
« Reply #5 on: April 06, 2006, 04:05:11 PM »
I thought a hectare was 10,000 m2, not 1 km2 which is 1,000,000 m2 ?
I think the reason why a hectare was used was because a lot of people purchase rural land by the hectare outside the USA.
« Last Edit: April 06, 2006, 04:05:11 PM by antw »
« Reply #6 on: April 06, 2006, 05:02:03 PM »
Metric / english.  English / metric.
Ten thousand square meters.  Ten thousand meters squared. Million. Billion. Whatever. My bad.
Ever heard of a solar panel being sold as a 0.000074132 acre panel?
Is that a US-32 or a GEPV-55M?
How many amps will a 0.000074132 acre panel put into a 12V battey at full sun?
How many amps will a 0.000074200 acre panel make?
If you kow what I mean.
« Last Edit: April 06, 2006, 05:02:03 PM by ghurd »
Nando
« Reply #7 on: April 07, 2006, 11:01:22 AM »
CORRECTING AGAIN AND AGAIN AND AGAIN
I do not know how my mind changed the values AGAIN -- OLD AGE I WOULD SAY !!!
Assuming a perfect panel surface of 10,000 square meters with a Solar insolation of 1 KW/M^2
A general insolation time would be around 6 hours, some say 8 hours, some 10 hours.
The efficiency of most panels are running around 17 %
~~~ 10,000 KW * 6 hours 0.17 efficiency = 10.2 MWH/ day
~~~ 10.2 MWH * 365 days /year = 3723 MWH-YEAR
A better power calculations would be to leave the daily hours for last and calculate the basic 1 hour.
10,000 M^2 * 1.0 KW/m^2 * 1 hour * 365 days *0.17 EFF = 620,500 KWH year with one (1) hour solar exposure = 620.5 MWH-YEAR PER HOUR OF INSOLATION
So if the insolation time is 10 hours the power would be 6205 MWH year
If the insolation time is 5 hours then 3650 * 5 = 3102.5 MWH year
Nando
« Last Edit: April 07, 2006, 11:01:22 AM by Nando »
