Author Topic: Your recommendation for a heater  (Read 30647 times)
GeeMac
« on: February 15, 2010, 11:24:23 AM »
I found these on the net. They're a bit expensive, but ignoring the cost will any of them work off a bank of 12 - 12 Volt Marine batteries?
http://www.princessauto.com/truck-trailer/truck-accessories/12v-heaters/list-all
Comments from exerienced solar folks welcome. :)
« Last Edit: February 15, 2010, 11:24:23 AM by (unknown) »
Re: Your recommendation for a heater
« Reply #1 on: February 15, 2010, 11:57:00 AM »
Define what you are looking for.
A 12V heater for a dump load or heat?  Or a heat exchanger for a solar liquid heater?
The only 12V heater that does Not use water from a heat source is the little 150W thing for $25.  I don't believe they actually use 150W because the wires on all I ever saw were far too tiny, and I hear they do not last very long.
I expect a pair of head lights would make more heat.
http://www.princessauto.com/truck-trailer/truck-accessories/12v-heaters/8237190-12v-2-in-1-ceramic-h
eater-/-fan
The others are pretty much fancy enclosed heater cores (like from a car) with a built in fan, which require hot engine coolant to flow through and provide the heat, and 12V means it has a 12V fan.  Could make one from a new automotive heater core and large (Huge) 12V muffin fan.
« Last Edit: February 15, 2010, 11:57:00 AM by ghurd »
GeeMac
« Reply #2 on: February 16, 2010, 03:49:02 AM »
Quite right Gurd. My mistake. Gall Dang it! I thought I had found the mother load for taking on the gas company.
« Last Edit: February 16, 2010, 03:49:02 AM by GeeMac »
