Author Topic: 6v. vs. 12v batteries  (Read 1800 times)
dtchild
« on: September 28, 2005, 11:30:20 PM »
Hey all,
What are the advantages of using 6v batteries and wiring them into 12v output as opposed to buying a higher amp hour 12v battery?
« Last Edit: September 28, 2005, 11:30:20 PM by (unknown) »
drdongle
Re: 6v. vs. 12v batteries
« Reply #1 on: September 28, 2005, 06:11:15 PM »
Can't think of any...
« Last Edit: September 28, 2005, 06:11:15 PM by drdongle »
pwr
« Reply #2 on: September 28, 2005, 06:57:00 PM »
If you're building a 12V bank, and you want lots of Amp-hours, then the 12V 8D battery in parallel is economical.
If your building a 24V bank, then you should consider 6V batteries because you can monitor how equal in voltage they stay over time, and treat any imbalance before you end up with destroyed cells.
At 48V, and for the same reason, you should use 2V cells or 6V units.
Depending on Amp-hours desired, 6V golf cart batteries give the most bang for the buck.  They are made in large quantities, most purchased by businesses who track quality through lifetime analysis, and its a market with lots of competition to keep prices down.  Some 6V golf cart batteries will give twice the number of cycles of an 8D made by the same company - and the two 6V batteries may even cost less.
« Last Edit: September 28, 2005, 06:57:00 PM by pwr »
dtchild
« Reply #3 on: September 29, 2005, 09:25:02 AM »
what do you mean by # of cycles? are you talking about charge to discharge cycles?
« Last Edit: September 29, 2005, 09:25:02 AM by dtchild »
whatsnext
« Reply #4 on: September 29, 2005, 11:56:24 AM »
"Depending on Amp-hours desired, 6V golf cart batteries give the most bang for the buck."
This is only true if your bank is small. With a big bank industrial batteries are the way to go. Not that golf cart gatts are not good it's just that reducing the total number of cell is a good thing longevity wise and no other battery can take the abuse a forklift battery sees every day.
« Last Edit: September 29, 2005, 11:56:24 AM by whatsnext »
drdongle
« Reply #5 on: September 29, 2005, 05:52:48 PM »
Good points I hadn't considered
« Last Edit: September 29, 2005, 05:52:48 PM by drdongle »
