Author Topic: guyed tower -- guy specification  (Read 950 times)
BillK
« on: June 28, 2004, 10:01:58 PM »
(blank)
« Last Edit: June 28, 2004, 10:01:58 PM by (unknown) »
Victor
Re: guyed tower -- guy specification
« Reply #1 on: June 29, 2004, 05:48:32 AM »
Assuming you are asking about tilt up towrs.
Whisper towers ( for H40 & H80) are made from 2.5" pipe(that's 2.875 OD). A 65' tower would have four anchors 32' from the base and four sets of wires, one every 15'.
« Last Edit: June 29, 2004, 05:48:32 AM by Victor »
wpowokal
« Reply #2 on: June 29, 2004, 08:24:36 AM »
I concure with 5kW 4 anchor points are required to allow the tower to be held from both sides (each 90 degree from pulling point) with one behind to stop it being pulled over centre.
If possible place the anchor points such that two share the load from your prevailing winds ie if Westerly winds were your strongest place anchors at N/W and S/W to share the load. Also if you have a sloping site try to arange the pull up point at the lowest position, this facilitates the raising of the tower, as technically the tower starts from above the horozontal if lowered uphill.
Minimum distance from base to each anchor point is 1/2 height, but most preferably tower height. The reason for this is that the greater the distance the less the stress on anchor wires & anchor points.
Last anchor wire should be as close under the tower top  that you can get without the possibility of fowling the blades. The top wire carries the force of the turbine wanting to move away from the wind, those below stop the tower from bending.
Bergy have an istallation manual on there site for one of their unit which is worth a read.
regards Allan
« Last Edit: June 29, 2004, 08:24:36 AM by wpowokal »
