Author Topic: Free blade calculator  (Read 9379 times)
edy252
« on: July 03, 2004, 11:48:04 PM »
hi....
there's a free Wind Turbine Blade Calculator at
http://warlock.com.au/bladecalc.htm
i didn't try it yet....but i hope it would give some help....
and to anyone out there who is considered as 'pro'....plz download this program and tell us what u think of it.
« Last Edit: July 03, 2004, 11:48:04 PM by (unknown) »
Michael
Re: Free blade calculator
« Reply #1 on: July 04, 2004, 08:56:34 PM »
i think it is really really good ;-)
« Last Edit: July 04, 2004, 08:56:34 PM by Michael »
DanOpto
« Reply #2 on: July 05, 2004, 07:51:16 PM »
Here is another calulator for comparison
http://www.ecs.umass.edu/mie/labs/rerl/Software/MiniCodeOverview.html
I compared the results of the Free blade calculator with the MiniCode from the U of Mass
I found that if the angle of attack in increased on the Free Blade calculator, the angles of attack go negative.
I inputed the same numbers into the U of Masss minicodes and the results do not go negative for high angles of attack.
I would not use the Free Blade Calculator to calculate angles of attack on my blade until I found out why the Free Blade Calculator allows the angles to go negative.
The Minicodes were very similar for 6 and 7 degrees of attack.
I prefer the minicode numbers as they do not go negative.
« Last Edit: July 05, 2004, 07:51:16 PM by DanOpto »
Michael
« Reply #3 on: July 06, 2004, 01:13:05 AM »
hi
i used the free blade calculator to calculate the the angle of attack and chord for the 1.8 metre tsr : 10 blades.
http://warlock.com.au/1800mmturbine.htm
then i made the blades with the exact angle of attack including the negative ones and exact chord length (approx +/- 0.5mm)
i measured the blade efficiency to be 0.30, which seems to be very close to the typical efficiency of a good 2-bladed turbine (0.3-0.35)
so i figure you need to have these negative angles to achieve high efficiency.
did you or anyone measure the efficiency of the blades made with the MiniCodeOverview.html program?
-Michael
« Last Edit: July 06, 2004, 01:13:05 AM by Michael »
