Author Topic: rectifier cooling  (Read 2373 times)
windrules
rectifier cooling
« on: July 06, 2004, 08:05:54 PM »
to finnish of my 2 phase alternater made from single phase motor I need to heat sink my rectifiers an wonder what everyone else does for this.Thought about just bolting them onto main frame just behind genny but dont know if this will cool them well or do i need to go to ally heat sink of somekind.I don't expect much above 16 amps total output and are using 32 amp recifiers.On my tape drive mill I have put diode right next to 12volt battery bank,but need to rectifie this one on or very near genny as I have about 30 meters of wire from mill to batt bank and the wire is to expensive to run 4 wires.
Thanks in advance,regards,
Mos
« Last Edit: July 06, 2004, 08:05:54 PM by (unknown) »
drdongle
Re: rectifier cooling
« Reply #1 on: July 06, 2004, 09:46:31 PM »
There are several factors to consider, the more surface area you have the more heat you can dissipate ( thats why stereos have large heat sinks with fins), and the more free air flow you have the better the dissipation ( this ties in with the heat sink) and the rating of the rectifier. You can never go wrong over rating the rectifier.
If in doubt use a heat sink mounted on the outside, perhaps under a shield to keep the rain and snow off.
Carpe Vigor
Dr.D
« Last Edit: July 06, 2004, 09:46:31 PM by drdongle »
« Reply #2 on: July 06, 2004, 11:30:30 PM »
   Just pop for the wire and use some lightening protection with it ground rod movs etc
 spend now save later . As for heat sinks a junk computer has some options .
« Last Edit: July 06, 2004, 11:30:30 PM by tecker »
RayW
« Reply #3 on: July 07, 2004, 04:47:52 AM »
   Junked projection tv's are an excelent source of some very nice heatsinks. Most tv repair shops should have some.
       RayW
« Last Edit: July 07, 2004, 04:47:52 AM by RayW »
Dan M
« Reply #4 on: July 07, 2004, 07:24:08 AM »
This may be a stupid question, but why would you want to keep rain and snow off of a heat sink?
-Dan M
« Last Edit: July 07, 2004, 07:24:08 AM by Dan M »
« Reply #5 on: July 07, 2004, 07:30:47 AM »
Dan M;
Well, I think rain or snow on the heat sink itself probably no big deal. However, the moisture could cause electrical shorting and corrosion in connections. Just my first thoughts.
« Last Edit: July 07, 2004, 07:30:47 AM by TomW »
« Reply #6 on: July 07, 2004, 11:22:11 AM »
In particular, the positive conductors will rot away - with metal atoms going into solution as ions.
« Last Edit: July 07, 2004, 11:22:11 AM by Ungrounded Lightning Rod »
windrules
« Reply #7 on: July 07, 2004, 04:24:42 PM »
Thanks guys I think I will do the heat sink from a computer as i have a few lying around with a rain cover as it never snows here.
Thanks for sugestion again,
Mos
« Last Edit: July 07, 2004, 04:24:42 PM by windrules »
baggo
« Reply #8 on: July 08, 2004, 04:24:53 AM »
Talking about rectifiers, has anybody used or thought of using Schottky diodes to construct the bridge rectifiers? They appear to have considerably less forward voltage drop than ordinary silicon diodes, hence their use as blocking diodes for solar panels etc.Using these should give less voltage drop across the bridge and hence less power wasted and less heat dissipated.
John
« Last Edit: July 08, 2004, 04:24:53 AM by baggo »
